95 1500 5.9 Ram Timing issue. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 2nd, 2009, 11:25 AM   #21
Freak
Wheelin the HD
Freak's Avatar
Already changed it. Replaced the MAP sensor and tried a alternate IAC checked electrical connections, even checked my air filter and PVC valve.
It gets resonalbe to run down the road (still no really drivable) when I unplug the TPS because it stops backfiring at 3/4 throttle, still get the bad slamming like the fuel pump is switching on and off. But if it was the pump I dont think it would back fire, and if it was the regulator I think it would be more consistant.
I am going to try picking up a computer for it next because at this point it just seems like its not reading the sensors right.
Old July 2nd, 2009, 07:02 PM   #22
Freak
Wheelin the HD
Freak's Avatar
Put a computer in it, and squat, anyone want to buy a computer?
Fuel pressure is 20lbs key on and 40lbs motor running...
Old July 2nd, 2009, 11:33 PM   #23
noodles
give 'er sh*t ay?
noodles's Avatar
things that control timming- crank sensor ( bellhousing) cam sensor ( dist), tps, map, coolant temp, iac, egr. i belive there is more but i can not remeber them. you hollowed out your cat? this did not start then? on the 95 i belive there is only one 02 sensor before the cat. so the cat should nto affect anything, becasue nothing is monotoring it afterwards. so your fuel pressure is a little low, but acceptable. if you are throwing a 02 code i would chase the wires, could be a broken wire causing it to miss fire.
do you have a oil leak? on my 94 it was sputtering and then just quit and would not run, took me 2 months to find the probelm. the crank senor got shorted out by oil from my rear mail oil leak. this will affect the timming and cause it to back fire.
do you smell fuel? if you smell fuel then you need to lean towards air. i mean, look for the sensors that control fuel to air ratio. i.e. tps, iac, fuel pressure, egr.
it sounds like the egr is stuck open. or partialy open. and my guess is when you unplug the tps the computer freaks, goes in to a base mode where it fuels according to rpm and doesnt worry about emmissions. so you can increase the air intake amount and correct the air to fuel ratio.
also check your grounds, dodge uses one ground for mutilpe sensors. they also like to use power for multiple sensors.
i have also heard of the plenum gasket leaking, causeing a rought idle, backfire and using of oil. the plenum is under the intake.
btw, you can reach the crank senor with out removing anything. ive done it many times.
Old July 4th, 2009, 04:03 PM   #24
Freak
Wheelin the HD
Freak's Avatar
Thanks for the tips.
Long story short the O2 was shot, I unplugged that and my fuel economy went way up, EGR is also blocked off but I don't think that was the problem, my truck is burning oil and I think the 02 was leaning out the mix too much. The EGR can stay blocked off since apparently I am getting oil and junk inside my intake so why make it worst? Not to mention that I might be getting more than 10mpg with it blocked off so it can just stay that way, that 9mpg shit sucks. This also effected my Torque converter lock up and my automatics shifting, why? who the fukc knows, but the trans that I thought was going to take a shit on me now acts like its almost new.
And yes, the 95 has 1 o2 sensor before the cat.
Old July 5th, 2009, 02:02 PM   #25
MiNi Beast
MiNi Beast's Avatar
So you are all better?
Heading to Lansing maybe next week you still need to get the CPU or not worried of it now?
Old July 5th, 2009, 02:04 PM   #26
Freak
Wheelin the HD
Freak's Avatar
got the computer already, I wanted it running for this weekend, but if you can get that winch cable from grandcherokee that would be nice. :D
Old July 5th, 2009, 02:06 PM   #27
MiNi Beast
MiNi Beast's Avatar
yeAH can prolly swing that.
Old July 5th, 2009, 02:09 PM   #28
94rangeron35s
bought a Jeep
94rangeron35s's Avatar
i just read this and i was going to point it at the O2 my self.. my ranger was doing the exact same thing and i was thinking all of the same things.. i also never changed o2s because i wasnt getting codes for o2s but a friend of mine looked and it and unplugged the o2 and it runs great now..
but glad you got it running good again ready to go play in the water up at silver again ?
Old July 5th, 2009, 02:13 PM   #29
Freak
Wheelin the HD
Freak's Avatar
Come over and help me find the vent on the trans and build a snorkel, then we can talk playing in the water...
Old July 5th, 2009, 02:19 PM   #30
94rangeron35s
bought a Jeep
LOL im not ready my ranger is Really Fawked from silver i got busted parts that i never thought would break lol (trans cross member and tranny mount)
Old July 5th, 2009, 02:26 PM   #31
Freak
Wheelin the HD
Freak's Avatar
thats what you get for having a ford LOL.
I spent a few bux on parts for my ram and need to catch up from that before I was going to head out, maybe 3 or 4 weeks from now. Need to get Joel out there with his new Jeep.
Old July 7th, 2009, 04:57 AM   #32
mopar96
Get Some!!
mopar96's Avatar
Sorry i just have the engine but no computer. It does have all the other stuff on it tho.
mopar96 is offline   Reply With Quote
Page generated in 0.42886 seconds with 59 queries
