95 1500 5.9 Ram Timing issue. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2009, 12:25 AM   #1
Freak
Wheelin the HD
Freak's Avatar
Default 95 1500 5.9 Ram Timing issue.
My 95 Ram 1500 4x4 5.9 360 V8 acts like it is stalling while at 1/2-3/4 throttle, typically when I move my foot a little, typically after a few miles driving at full temperature, but its not consistent, and I cant cause it when I have time to look at it. Some times it back fires, some times it just falls on its face then picks right back up, sometimes it takes a bit of cranking to start, some times it starts right away. Its also developing a rough idle and stalling condition when it idles for a minute in park or neutral. Exhaust smokes white when cold but its not using coolant, burns about 2 quarts of oil every few thousand miles exhaust pipe has a nice sooty black, as it always has been.
Problem started occurring after my trip to Silver Lake last weekend.
So, I am leaning to the Crank Sensor, might explain the white smoke as not enough advance and unburnt fuel, and not burning hot enough would also explain the carbon build up, and the occasional miss, also had a tune up about 10K miles ago.
Old June 25th, 2009, 11:02 AM   #2
Freak
Wheelin the HD
Freak's Avatar
I think I was wrong, got it to act up again today, when I unplugged the TPS it started and ran down the road, but for obvious reasons stalled when I came to a stop.
I don't even think this truck has a crank sensor TBH, I can't find the damn thing if it does...
Old June 25th, 2009, 11:10 AM   #3
greygoose
I'm the dude
greygoose's Avatar
My buddy had a similar problem on the same truck / motor. He was getting codes that said multi cylinder miss fire. it turned out to be the cat.
Old June 25th, 2009, 11:17 AM   #4
Freak
Wheelin the HD
Freak's Avatar
Cat? I killed that a while ago...
My truck hasn't thrown a code since this started, it was throwing 02 codes before, but that is because the cat is hollow and its not in the direct stream of the exhaust... can change the 02 sensor and get another 02 code 5 minutes later. I guess this could point to another problem... but I haven't been able to pin anything down and it ran GOOD until the last few weeks, however, it wasn't until on the way home last Saturday that it became nearly undriveable.
Also, when its acting up it wont idle. The idle was good up until 2 weeks ago but it wasn't erratic enough to warrant any investigation until now.
Old June 25th, 2009, 12:40 PM   #5
Freak
Wheelin the HD
Freak's Avatar
I just swapped the TPS with a used one I had, same problem.
Old June 25th, 2009, 01:28 PM   #6
Freak
Wheelin the HD
Freak's Avatar
god I don't want to take the manifold off to get into the distributor... if I unplug the MAF sensor it gets worst... but would MAF cause it to backfire?
Old June 25th, 2009, 08:21 PM   #7
MiNi Beast
MiNi Beast's Avatar
Do you have a IAC on that, cause mine did that stall at stop signs and what have you and I unplugged it and ran fine, so left it that way.
Can't say I know much about Dodges, as they are built by a crap company
Old June 25th, 2009, 08:59 PM   #8
Freak
Wheelin the HD
Freak's Avatar
Already checked next step is the pickup in the distributor... it seems to be a timing issue...
Old June 25th, 2009, 10:34 PM   #9
MiNi Beast
MiNi Beast's Avatar
yeah time for a new damn driver
Old June 26th, 2009, 05:59 PM   #10
Freak
Wheelin the HD
Freak's Avatar
What exactly do we have to control the timing on this truck?
Old June 26th, 2009, 06:10 PM   #11
HVYRTFT
Reed my teef
HVYRTFT's Avatar
I believe it's all computer controlled.
I.E. you can't just turn the distributor CC or CCW.
Old June 26th, 2009, 06:17 PM   #12
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
PCM controls the timing, the only sensor inside the distributor is a cam position sensor.
Also, the truck should have a crank position sensor, on the trans bellhousing, somewhere near the oil pressure sender, as the service information I have states that the OPS and EGR tube may need to be removed for access.
1988JeepXj is offline   Reply With Quote
Old June 26th, 2009, 06:34 PM   #13
Freak
Wheelin the HD
Freak's Avatar
Your right. Moving the distributor wont adjust the timing, if you move it too far it wont run, but about 2inches of adjustment for the "run zone" no matter what its rotated it will remain the same. Mine happens to be 10 degrees, I think...
you make me sad I was hoping it wasn't back there... I cant phiscally see it..
Did check the codes and got #66 bad computer. Going to reset it and see what we can do...
I was asking what sensors make cause the timing to adjust, cam, crank, TPS, and MAF seems right...
Old June 30th, 2009, 11:46 AM   #14
Freak
Wheelin the HD
Freak's Avatar
I think I found the crank sensor...
I think I have to take the passenger side exhaust manifold off to get at it...
Old July 1st, 2009, 08:43 AM   #15
mopar96
Get Some!!
mopar96's Avatar
I have a 1996 dodge 5.9 liter complete engine if it comes down to it. LoL. Make you a good deal.
mopar96 is offline   Reply With Quote
Old July 1st, 2009, 09:19 AM   #16
Freak
Wheelin the HD
Freak's Avatar
have you got a computer? LOL seems to be running down the road all right now, but keeps stalling when I come to a stop... Ive about had it with this thing.
Old July 1st, 2009, 09:50 PM   #17
dodgeboy
redneck truck club
dodgeboy's Avatar
whats the coolant temp sensor telling the computer for a temp?? get a scanner that shows data and see whats doing what would help out alot! see whats giving the right info.
dodgeboy is offline   Reply With Quote
Old July 1st, 2009, 10:10 PM   #18
mudbillyredneck
mudbillyredneck's Avatar
sounds like a case of dead pedel ?
mudbillyredneck is offline   Reply With Quote
Old July 2nd, 2009, 02:37 AM   #19
Freak
Wheelin the HD
Freak's Avatar
the gauge in the dash is showing 200-210 there is only one temp sensor on this motor. If I could get a scanner on this one I would have done it damn thing is 2 peace plug, and I dont have the right connector for it, nor can I find one
ok, explain more?
It was running fine around town in the cooler weather, but when I ran up to Fremont today it flipped out on me as soon as I got off 131 @ post drive, backfiring and feeling like I was stomping the pedal then letting go... When I unplug the throttle position sensor it stops backfiring and there is a narrower area where the throttle jumps up and down.
Old July 2nd, 2009, 07:48 AM   #20
dodgeboy
redneck truck club
dodgeboy's Avatar
try to replace the TPS with a new one... it stalled when unpluged because the computer didnt know where the throttle position was to keep it running. if the new one doesnt work take it back.
Page generated in 0.52412 seconds with 83 queries
