shortest tcase. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 24th, 2009, 12:03 PM   #1
caveman
GeoDude
caveman's Avatar
Default shortest tcase.
picking up a jeep this weekend with chevy drivetrain. it has a 208 in it right now and rear shaft is really short. are there any shorter chevy cases that are a pass side drop that will bolt to a 700r4?
Old June 24th, 2009, 02:34 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
dana 20 with an adapter should work
Old June 24th, 2009, 02:37 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
http://www.novak-adapt.com/catalog/kit_107.htm heres a kit if you locate a dana 20
Old June 24th, 2009, 02:40 PM   #4
caveman
GeoDude
caveman's Avatar
i'm a poor ass white boy tho
Old June 24th, 2009, 02:43 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
then good luck. i'd stick with the 208 and if it doesn't have one already get a slip yoke eliminator kit. that will help with the rear driveshaft problem by reducing stress on the t-case output. these people make a kit for it. http://www.high-impact.net/transmiss...se_sle_kit.htm
Old June 24th, 2009, 02:50 PM   #6
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
They also make a NP 241 that you can gat an SYE and a 4:1 kits for later if you want. I just sold 1 a couple months back for $250 for that very reason. The guy needed more real estate between the output shaft and the rear diff.
90-91 burbs had them.
Old June 24th, 2009, 03:04 PM   #7
caveman
GeoDude
caveman's Avatar
i could always cut fender and stretch the damn thing for free....
Old June 24th, 2009, 03:36 PM   #8
outalne94z71
bouncingtrucks.com artist
outalne94z71's Avatar
i have found them in 88-91 along with the k5 of the same vintage
outalne94z71 is offline   Reply With Quote
Old June 24th, 2009, 03:40 PM   #9
caveman
GeoDude
caveman's Avatar
thanks guys.
Old June 29th, 2009, 09:10 AM   #10
PavementPounder
PavementPounder's Avatar
Add the length of the adapter required to the Dana 20 before choosing it over the Dana 300 that already has the NP bolt pattern.
Old June 29th, 2009, 12:33 PM   #11
Ebrown
Ebrown's Avatar
I don't think there is a 4.1 gear set for the Chevy passenger side drop Np-241 case.
Ebrown is offline   Reply With Quote
Page generated in 0.28439 seconds with 56 queries
