99 grand caravan se sport elec issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2009, 08:41 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 99 grand caravan se sport elec issue
My wife left her windows down about 3 weeks ago and of course it rained. The drivers side dash got soaked. Now when you start the car her headlights and running lights flash like a slow strobe but if you turn the lights on the strobe effect stops. I do not know if it is related but her cig. lighter stopped working and the 60 second headlight delay does not work anymore because even if you leave the headlights on as soon as the ignition is shut off the lights turn off.
I check the fuses and all is good. Is there a relay that may need to be replaced and are the 2 issues linked together.
Silver Bullet is offline   Reply With Quote
Old June 25th, 2009, 04:44 PM   #2
Silver Bullet
Bump...anyone got any info.
Old June 25th, 2009, 04:49 PM   #3
firehawk
Live Action!
firehawk's Avatar
Probably gonna need some sort of electrical module.
Might just need the headlamp switch?
Old June 28th, 2009, 09:10 PM   #4
Brods
Donít know if this will help since it may be different on a 99. On a 2000 sport the headlamps are completely controlled by the Body Control Module (BCM). The headlamp switch just sends a signal to the BCM and then the BCM turns on the relays controlling the lights. The BCM also controls the headlight time delay. The BCM is located under the dash to the left of the brake pedal, about were the fuse box used to be on old cars. You may want to check to see if its wet or if the terminals are corroded.
The 2000 service manual lists the following possible causes for the headlights randomly flashing:
1. Poor lighting circuit Z1-ground
2. High resistance in headlight circuit
3. Loose or corroded terminals or splices in circuit
4. Faulty headlamp switch
5. Faulty low beam relay or high beam relay
You can test the headlamp switch with a digital multi meter equipped with a diode test. If you want to try that I can email you a picture of the charts with the pinouts and the resistance values to test for. Again this is for a 2000 so if the 1999 is different then it is of no use to you.
Old June 28th, 2009, 09:12 PM   #5
firehawk
Live Action!
firehawk's Avatar
That seems to be some great info.
Do you work at a dealer?
I was wondering where you came up with that kind of info and is there a website that can be shared?
Old June 28th, 2009, 09:20 PM   #6
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
'99 is the same judging by how the wiring diagram looks.
1988JeepXj is offline   Reply With Quote
Old June 28th, 2009, 09:55 PM   #7
Brods
I usually get the factory service manual for the vehicles I own. Just happen to have the manual for 2000 Grand Caravan sport.
Old June 29th, 2009, 03:59 PM   #8
Silver Bullet
i must say that is some nice info. I would assume it is the same. I can hear the relay in the BCM clicking. Now to find the issue
Old July 12th, 2009, 11:01 AM   #9
rtellason
Got the meter, I could use the info. New to this forum, I am having a bit of trouble finding the PM or email functions...
rtellason is offline   Reply With Quote
Page generated in 0.80136 seconds with 50 queries
