1996 blazer tires - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2009, 09:28 PM   #1
preston
No brains, No headache
preston's Avatar
Default 1996 blazer tires
i have a currently stock 1996 blazer 4 door 4WD which i would like to put some firestone wilderness A/T's under. the tires are 32/11.50/R15.
what kind of lift would i have to put on it to make them clear? the truck will mostly be on the road with little or probably no hard off-roading.
preston is offline   Reply With Quote
Old June 23rd, 2009, 11:46 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
your not getting those tires on it without 5 or 6" of lift.
Old June 25th, 2009, 02:31 PM   #3
BlueBlazer98
Winning
BlueBlazer98's Avatar
my buddy got 33's under his 99 four door blazer with a 2" BL, bigger shackels in the rear which added about 2.5" of lift. and he put some ZR2 T- bars, and some triming. so maybe a 4" lift would be good
BlueBlazer98 is offline   Reply With Quote
Old June 25th, 2009, 02:35 PM   #4
HighTech Redneck
Cowboy Up
HighTech Redneck's Avatar
could go with a 3" suspension, 2" body
HighTech Redneck is offline   Reply With Quote
Old June 25th, 2009, 02:45 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
my 91 has a 3" body 2 inch torsion bar and 2 inch shackles and i have 32 11.50's and they rub badly on turns and under suspension flex
Old June 25th, 2009, 11:17 PM   #6
preston
preston's Avatar
if i go 31" tires can i just use a 2" BL?
Old June 26th, 2009, 01:25 AM   #7
beedle4
beedle4's Avatar
Depends on how you drive.
I have a ZR2 5" suspension and 1" Body lift with 33's and I rub on hard compression.
I would stick with the 2" body lift and either a 30x9.5, or 31x10.5 but may need some trimming.
Stick with stock wheels too, any thing with less backspaceing just make rubbing issues worse.
Old June 27th, 2009, 11:13 AM   #8
preston
preston's Avatar
thanks beedle, i think im going to end up with some 31x10.5's
Old June 30th, 2009, 02:05 PM   #9
Disturban
Disturban's Avatar
I think the only lifts kits you can get for a S10 are either a 5" suspension lift or a 2" or 3" body lift. The suspension lift kits for S10"s are big dollars and probably cost more then your truck. All my S10's I have ever owned I put 30x9.5's on them and had no rubbing at all, one of them came with a 3" body lift and 31x10.5's and did not rub either but it looked gay as hell seeing the frame that low...not my style but I bought the truck that way. Just get ya some good 30x9.5 Mud Terrains and you will be surprised at where you can go with it S10's rock
Page generated in 0.34646 seconds with 50 queries
