*SOLD*'88 XJ D35 3.55s open diff - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2009, 02:15 PM   #1
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Default *SOLD*'88 XJ D35 3.55s open diff
1988 Dana 35 rear axle, its supposed to be a non c-clip, but the last time the cover was off I forgot to check .
Its completely removed from my XJ ready to roll, still good, just needs a pinion bearing and some brake parts.
Intact, drum to drum, although the brake parts inside are questionable, shoes will be a requirement, possibly drums, hardware and wheel cylinders as well.
Mechanically the axle rolls just fine, no wheel bearing noise, etc. However, it does have what I believe to be a pinion whine, as you can hear it whine under a load around 40, but on the freeway and coasting at any speed, its quiet. It doesn't have excessive play in the gears, and its perfectly quiet around corners. Mileage on the jeep is 242,000 but for this thing to be mechanically sound aside from a pinion bearing I have to believe at some point it was overhauled.
IMHO I don't believe this axle is worth much, but because I have to have a price I'll say $50 obo
Make me an offer ! Need it gone.
1988JeepXj is offline
Old June 23rd, 2009, 10:26 PM   #2
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
Originally Posted by 1988JeepXj View Post
1988 Dana 35 rear axle, its supposed to be a non c-clip, but the last time the cover was off I forgot to check . I'm upgrading to a low mileage 8.25 29 spline that I got for a killer price, so this one will be up for grabs.
Its still currently in the vehicle, but will be swapped out in a week, I'm trying to keep it from laying around in the back yard once its out.
Mechanically the axle rolls just fine, no wheel bearing noise, etc. However, it does have what I believe to be a pinion whine, as you can hear it whine under a load around 40, but on the freeway and coasting at any speed, its quiet. It doesn't have excessive play in the gears, and its perfectly quiet around corners. Mileage on the jeep is 241,000 but for this thing to be mechanically sound aside from a pinion bearing I have to believe at some point it was overhauled.
If you happen to get near Holland some day let me know
not willing to drive to go get but if your going this way anyway ... I wouldn't mind a spare.
two_much_talk is offline
Old June 26th, 2009, 06:29 PM   #3
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
I unfortunately don't go that way, but if something comes up I will let you know.
Bump for an ol' trusty Dana turdy-five
Old July 23rd, 2009, 02:05 PM   #4
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
TO THE TOP, its been a while, but this sucker is FINALLY out.
Come get it
Old July 24th, 2009, 03:25 PM   #5
two_much_talk
still interested
Old July 25th, 2009, 07:02 PM   #6
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Bump
Old July 26th, 2009, 04:06 PM   #7
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
ttt
Old August 6th, 2009, 09:02 PM   #8
two_much_talk
pm sent
Page generated in 0.24836 seconds with 47 queries
