1 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2009, 08:55 PM   #1
deerebowtie
Unchained
deerebowtie's Avatar
Default 1
23
Old June 23rd, 2009, 07:04 AM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Why wouldn't you pick up an SM465 bell housing instead? I'll talk to the guy that i work w/ and see if he wants to sell his or not!
Old June 23rd, 2009, 08:57 AM   #3
Hoss Blazer
!SPARTY ON!
What t-case are u gonna be using? The SM465 take a special case it a 10 spline input!
Old June 23rd, 2009, 09:46 AM   #4
outalne94z71
bouncingtrucks.com artist
outalne94z71's Avatar
only on pre 78 sm465's, 78-90 they were 32 spline
outalne94z71 is offline   Reply With Quote
Old June 23rd, 2009, 11:17 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
to answer your question yes you should have a good fit between the bellhousing and the input bearing.
Old June 24th, 2009, 09:35 AM   #6
Hoss Blazer
!SPARTY ON!
So what enine you gonna put in front of it...that 454?
Old June 24th, 2009, 02:11 PM   #7
Hoss Blazer
!SPARTY ON!
No he said he didn't want to sell it! I would reconsider running a manual w/ a big block! Thats why im switching to an auto because i have a 496 going in sometime
Old June 24th, 2009, 02:56 PM   #8
outalne94z71
fyi,a sm465/205 is the shortest combo possible so if you run more than a 6" lift you will have driveshaft issues.
Old June 24th, 2009, 03:30 PM   #9
outalne94z71
you will have serious problems getting a front shaft under that kind of lift with that short of a combo, a 8" lift we just did with that same combo led us to chaining the front so there was no droop or it would have blown the shaft and that was with clearancing the yokes.
you are going to have to run a 2wd sm465 and a divorced case for that lift, no way around it, even high angle does not make a shaft for that kind of shaft angle
Old June 25th, 2009, 09:42 AM   #10
Hoss Blazer
!SPARTY ON!
Originally Posted by deerebowtie View Post
this is a play/trail truck only...I haven't gotten to drive a manual in some time and I miss it. if i wind up not liking it, I'll wind up going with the same combo as you are working on right now.
Ya the SM465 isn't really good for mud thats the main reason im switching. It's not worth it putting it in first gear to go through mud because it pegs when you step on the gas. So that only leaves you w/ 2nd. It's harder than hell to try to get it into third and steer when the ruts are taking you in every direct. It's just gonna be easier w/ an auto. But i really like it the rest of the time.
Page generated in 0.22460 seconds with 53 queries
