98 1500 spacer lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2009, 07:03 PM   #1
wildbill4770
Web Wheelin at its finest
wildbill4770's Avatar
Default 98 1500 spacer lift
want to use a spacer lift in a 98 1500 and was wondering what mods are necessary i.e shocks, sway bar , track bar, brake lines wan't to do this as cheap as possible thanks for the input
wildbill4770 is offline   Reply With Quote
Old June 22nd, 2009, 10:18 PM   #2
Red Ram01
Mr Ohara
Red Ram01's Avatar
Send a message via AIM to Red Ram01
to be honest with you i have spacer on my 2001 ram very easy and looks good but you can get more lift and and cheaper to just swap out the old springs for ram 2500 springs
Red Ram01 is offline   Reply With Quote
Old June 23rd, 2009, 03:35 PM   #3
wildbill4770
ok will look into it did you have to modify anything else shocks brake lines the sway bar track bar that is the info that i need thanks though
Old July 30th, 2009, 01:11 PM   #4
DodgeitRamit
DodgeitRamit's Avatar
No other modifications will be necessary . . . although longer shocks are recommended. Check on Ebay- you should be able to pick up a set for as cheap as 75$. Then you will need spring compressors which you can pick up a cheap set at Harbor Freight for about 15$. Other than that is is pretty simple install.
DodgeitRamit is offline   Reply With Quote
Page generated in 0.15567 seconds with 35 queries
