T-5? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2009, 10:52 AM   #1
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Default T-5?
I can't seem to get mine to shift into or out of gear anymore when its running so I think its life is over. Does anyone have a T-5 around they want to get rid of?
Mulely is offline   Reply With Quote
Old June 22nd, 2009, 11:01 AM   #2
PavementPounder
PavementPounder's Avatar
But it shifts when the motor is off?
Old June 22nd, 2009, 11:09 AM   #3
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
What type of vehicle? 2wd or 4wd? I have a 2wd one from an '87 Camaro if you need one.
Red68Camaro is offline   Reply With Quote
Old June 22nd, 2009, 11:57 AM   #4
Mulely
Mulely's Avatar
Yeah, it shifts okay when the motor is off. I kinda think the clutch isn't disengaging totally, like the slave cyl isn't moving the throwout arm enough. I'm kinda preparing for the worse though by looking for a new tranny
Old June 22nd, 2009, 11:58 AM   #5
PavementPounder
It sounds like a clutch-related issue. That is how my trans behaved when the pressure plate collapsed.
BTW, Chevy T-5's will not fit a CJ correctly.
Old June 22nd, 2009, 12:05 PM   #6
Mulely
Mulely's Avatar
there is a lot of play in my fork right now from rest position to the point of engagement. It might be a collapsed pressure plate...
Old June 22nd, 2009, 12:13 PM   #7
PavementPounder
Fork? Or shift lever? The T-5 has a replaceable bushing, clip, and boot that eliminate the slack from the shifter. It happens to all T-5's.
Old June 22nd, 2009, 12:13 PM   #8
greygoose
I'm the dude
greygoose's Avatar
I had the same problem in my manual trans years ago. It turned out to be the slave cylinder.
Old June 22nd, 2009, 12:56 PM   #9
Mulely
Mulely's Avatar
the fork. I can move it back and forth easily. I don't think its the slave cyl because thats pretty new and theres no leaks
Page generated in 0.18661 seconds with 50 queries
