Custom Driveshafts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 20th, 2009, 02:01 PM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default Custom Driveshafts
Is there anywhere in the detroit area to get driveshafts cut down, lengthened or custom built?
BowtieWrangler is offline   Reply With Quote
Old June 20th, 2009, 02:09 PM   #2
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Drives & Shafts Specialties Inc‎
27559 Schoolcraft Road, Livonia, MI‎ - (734) 522-9440‎
Are you actually IN detroit or just nearby?
1988JeepXj is offline   Reply With Quote
Old June 20th, 2009, 03:02 PM   #3
redline8300
Redline8300
redline8300's Avatar
Joint Clutch and Gear. They are I think in Romulus just north of 94 east of 275.
redline8300 is offline   Reply With Quote
Old June 20th, 2009, 11:19 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
do it yourself
Old June 20th, 2009, 11:32 PM   #5
Mclovin
"The Situation"
Mclovin's Avatar
YEs !
Originally Posted by Plato2k5 View Post
do it yourself
Trail rig YES Daily Driver NO
Old June 21st, 2009, 02:18 AM   #6
BowtieWrangler
Nearby south of detroit
and to the do it myself i will if i have to but id rather have someone do it that can balance it, it is mainly a trail rig but i do enjoy takin it out for a cruise every now and then
Old June 21st, 2009, 09:38 AM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Originally Posted by Mclovin View Post
YEs !
I drive mine around the streets....no issues? Just take it in and have it balanced.
Old June 21st, 2009, 09:50 AM   #8
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
x2. never needed to have balanced
samurai2240 is offline   Reply With Quote
Old June 21st, 2009, 10:43 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I have not either... just don't go above 80mph and your fine
Or you can do the trans fluid trick.
Old June 22nd, 2009, 12:04 AM   #10
Yota Bill
I've built them for street vehicles, only had one guy saying it was vibrating (I had already told him before hand he should take them in to get balanced)...turned out he had other problems, and the shafts were fine...
I use a set of v-blocks and a dial indicator and get the runout as close to zero as possible, though I have never gotten one quite to zero...
Old June 22nd, 2009, 12:09 AM   #11
Ready4Wheelin
Ready4Wheelin's Avatar
Dynotech Engineering in Troy.
www.dynotechengineering.com
Ready4Wheelin is offline   Reply With Quote
Old June 22nd, 2009, 12:34 AM   #12
Blackjackbender
i can do 75mph with my homebuilt shaft without feeling any vibes. just gotta take your time with the tape measure and if you want to be real anal mount it up and use a dial indicator to check the read out on it. have a uniform weld will helps also/maybe grinding it smooth.
Old June 22nd, 2009, 12:45 AM   #13
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I can hold 75 and not feel it...but past 80 you can. I mounted it, tacked it, spun it and taped it straight, than welded it. I actually have to do it again tomorrow as I have the indexing wrong
Old July 2nd, 2009, 10:54 AM   #14
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
Originally Posted by Blackjackbender View Post
i can do 75mph with my home built shaft without feeling any vibes. just gotta take your time with the tape measure and if you want to be real anal mount it up and use a dial indicator to check the read out on it. have a uniform weld will helps also/maybe grinding it smooth.
X50 as ever since I have learned to make my own in my teenage years I have always had home built shafts back in the day I had them rebalanced now if its a bogger i just weld it and if its a DD i put a little trans fluid in it
scramblerman72 is offline   Reply With Quote
Old July 2nd, 2009, 12:19 PM   #15
I'm digging the trans fluid idea, this is why I read
Old July 4th, 2009, 12:49 AM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
trans fluid for the win for sure! I put 1/2 qt. in mine... its out of balance a bit, but with the trans fluid you would never know! No vibes at all going down the road.
Old July 4th, 2009, 01:11 AM   #17
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
B&G Truck in Warren on 9 Mile
Motorcitydak is offline   Reply With Quote
Old July 15th, 2009, 06:17 PM   #18
biggnbrittle
hangindixirebel
biggnbrittle's Avatar
Send a message via AIM to biggnbrittle
what exactly does the trans fluid do?
biggnbrittle is offline   Reply With Quote
Old July 15th, 2009, 08:11 PM   #19
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
balances the drive shaft.
Old July 16th, 2009, 02:19 PM   #20
rsturton
rsturton's Avatar
After dialing it in and welding it the only way to get the shaft to zero is to dial it again after welding it and heating it red hot it the high spots and colling it with a wet rag. This will shrink it on that side and bring it to zero. This is the way I was taught to do it when I worked at Toledo Driveline/Certified Powertrain/Fleet Trucks building drive shafts.
rsturton is offline   Reply With Quote
Page generated in 0.43511 seconds with 83 queries
