body swap/ spedo problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2009, 11:14 PM   #1
why
why
why's Avatar
Default body swap/ spedo problem
I have a 87 3/4 ton frame with a 208 t case that has a 1991 extended cab on it I know the 91 take signal generator in the t case and the 87 was a cable. Dose anyone know of a signal generator to fit the 208 case?
why is offline   Reply With Quote
Old June 19th, 2009, 03:55 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you should be able to check the GM parts guide. I know there were 208s around, so there has to be a speedo set up to make it work.
Yetti
Page generated in 0.55100 seconds with 29 queries
