how to level out a 2wd c1500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2009, 09:06 AM   #1
Jdc215
Jdc215's Avatar
Default how to level out a 2wd c1500
i have a coworker that asked me if i could help him level out his 2wd chevy but im not sure how the front end is set up. i see it has coil springs but i dont know much else. i think its a 96 or so. he wants it leveled out so it dosnt ride so nose down. can coil spacers be purchased or is it better to get new coils. i dont think he will need new shocks or brake lines because he just wants it riding at stock or maybe 1" over stock in the front. he needs about 2" to get what he wants. any pointers on how to accomplish this would be helpful.
Jdc215 is offline   Reply With Quote
Old June 18th, 2009, 07:16 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
I just did coil spacers in one of those last week. The job was relatively painless, but the spring compressor didn't like the tight springs. The customer wanted his aluminum spacers put under the springs. It raised it up approx 2" and it did level it out nice. Will defiantly need a alignment after because the camber will be way out.
I think the biggest bitch of the job was getting the shocks out without screwing them up.
Old June 21st, 2009, 06:20 PM   #3
Jdc215
Jdc215's Avatar
any idea where to get spacers? or dimensions, i have access to a machine shop and have made coil spacers before.
Old June 21st, 2009, 06:29 PM   #4
redmud
10 0011 10101
redmud's Avatar
we can get them for you at the shop, I've sold a few set of them. Hosejockey put them in a 2wd 2500 last fall.
BDS Suspension
How can you land a space ship on the moon? How can a snake eat an aligator? how does the internet work? some questions are not meant to be answered by man alone.
redmud is offline   Reply With Quote
Old June 21st, 2009, 06:40 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
The ones I did were like this.
ebay ad
Old June 21st, 2009, 09:28 PM   #6
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
and they were cheap and did the job perfectly
remember on those trucks a 2 inch lift spacer may only be 1 inch thick or so because of the way the control arm is.
Old June 21st, 2009, 09:51 PM   #7
Jdc215
Jdc215's Avatar
how much?
Old July 31st, 2009, 03:41 PM   #8
four_by_ken
Need a strap?
four_by_ken's Avatar
2wd... Make the rear match the front.
four_by_ken is offline   Reply With Quote
Old July 31st, 2009, 04:06 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
drop the rear simple and cheap
Old August 1st, 2009, 12:15 AM   #10
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
You could look for different spindles too. That would give the lift and keep the steering geometry correct. Try looking for a 2wd lift kit and just don't put the rear in.
BAD93SBLZR is offline   Reply With Quote
Old August 1st, 2009, 11:17 AM   #11
Michigan ZJ
I would go with the spindles or springs. Stay away from the ball joint spacers, not the best set up from what I have dealt with.
Michigan ZJ is offline   Reply With Quote
Page generated in 0.31338 seconds with 56 queries
