Limited Slip/Posi for Ford 8.8 and Flowmasters - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2009, 07:10 AM   #1
bmx0964
bmx0964's Avatar
Default Limited Slip/Posi for Ford 8.8 and Flowmasters
I need a Posi or Limited Slip for a Ford 8.8 rear. I dont know if it matters but it has 4.10 gears in it.
I also need 2 matching Flowmasters or something similar.
bmx0964 is offline   Reply With Quote
Old June 18th, 2009, 03:17 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
28 spline or 31 spline?
I have a 31 spline L/S, repacked with Ford Racing Clutches and re ordered. They are different from the OEM set, not sure if the clutch material is, but they had alot more than the OEM had left. I re-used one original set on either side. It's still re-packed uber tight though and has over 2x the original disk orders friction surface. Decided not to use it and just go welded.
$60
*Oh, and 8.8"s don't have any carrier breaks.
Last edited by Captain Ledd; June 18th, 2009 at 03:29 PM. Reason: That reads a WHOLE lot better..
Old June 19th, 2009, 11:00 AM   #3
bmx0964
bmx0964's Avatar
I believe its a 28 spline. I would need to rip it apart to tell but I still be interested in buying. The rear end is out of a 96 ford explorer with 4.0L v6 if that helps at all.
Old June 19th, 2009, 11:31 AM   #4
warner-racing357
WARNER-RACING
warner-racing357's Avatar
I'm pretty sure all the explorers came with 31 spline
warner-racing357 is offline   Reply With Quote
Old June 19th, 2009, 11:50 AM   #5
bmx0964
bmx0964's Avatar
Ok thanks, ill pull it apart and look.
Old June 19th, 2009, 02:17 PM   #6
Captain Ledd
Ranger Addiction?
X2 on the 31 spline. Unless they put something else in there or they lied to you, It'll be 31.
Since you're in Fenton I'll PM you my address. Or even meet up somewhere, I'm out that way on occasion.
Old June 19th, 2009, 02:32 PM   #7
bmx0964
bmx0964's Avatar
well its a 97 ford ranger that its going in. when i bought the truck the guy that had it before me said the rear end was out of a 96 explorer with the 4.0 and it had 4.10 gears. it also has disk brakes if that means anything.
also how far away is davisburg from fenton?
Old June 19th, 2009, 03:42 PM   #8
Captain Ledd
Ranger Addiction?
2 towns over. 10-15 miles somewhere abouts.
http://maps.google.com/maps?f=d&sour...,0.254059&z=12
Old June 19th, 2009, 06:28 PM   #9
bmx0964
bmx0964's Avatar
oo ok well maybe we could meet at phils party store if you know where that is. it should be close for you and Im out that way a lot.
Old June 19th, 2009, 07:37 PM   #10
Captain Ledd
Ranger Addiction?
No idea where that is lol.
Old June 20th, 2009, 12:38 AM   #11
bmx0964
bmx0964's Avatar
at the corner of hickory ridge and rose center
Old June 20th, 2009, 01:33 AM   #12
Captain Ledd
Ranger Addiction?
Ok then. Never been that far down those roads before, but I know the roads from the Twp. Cleanups.
When do you want to meet up?
-Actually I am going to be busy Sunday and likely Monday as well. But as it stands other days are fine.
Old June 20th, 2009, 01:36 AM   #13
bmx0964
bmx0964's Avatar
wenever just let me no a day ahead
Old June 25th, 2009, 07:13 AM   #14
bmx0964
bmx0964's Avatar
Got the Limited Slip... Still need mufflers...
Page generated in 0.24709 seconds with 65 queries
