speedometer problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2009, 10:14 PM   #1
93XJcountry
Nothing Runs Like a Deere
93XJcountry's Avatar
Default speedometer problems
CALLING ALL 88-98 GM TRUCK GURUS!!!!!!!!!!!!-okay i have my 92 sierre and today the speedometer stoped working. it will go from 0 to 10 then to 35 and back down to 0 and stay there. and its a 350 mated with a 4l60e. i would like to know asap so i can fix befor i go to college. thanks.
93XJcountry is offline   Reply With Quote
Old June 17th, 2009, 10:50 PM   #2
outalne94z71
bouncingtrucks.com artist
outalne94z71's Avatar
check the ground wire on the drac unit(white box behind glove box)
there is not much to the system its either the output sensor on the trans(on t-case on 4wd) , the green(with black tracer) and purple(white tracer) braided wire from it to the drac, the drac itself or the cluster is bad, 92-94 is the same cluster, 91 is the oddball year and will not work(it's the 88-91 style plug and has internal calibration)
outalne94z71 is offline   Reply With Quote
Old June 18th, 2009, 06:58 AM   #3
93XJcountry
thanks, i will do that. i had no clue about the drac unit.
Old June 18th, 2009, 09:42 AM   #4
93XJcountry
well the sensor at the t-case was fine along with wires going out of it so i will tear into my glove box when i get back home.
Page generated in 0.23155 seconds with 35 queries
