14 Bolt Full Float Open Carrier - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2009, 03:12 PM   #1
bearlys2005
bearlys2005's Avatar
Default 14 Bolt Full Float Open Carrier
I'm looking for a good used 14 Bolt open carrier that will accept 4:56 or numerically higher gears. I will consider other carriers as well.. What do ya have?
bearlys2005 is offline   Reply With Quote
Old June 17th, 2009, 10:38 PM   #2
lt1yj
I have one for a 4.10 and down gear set. $75 in Holland
lt1yj is offline   Reply With Quote
Old June 17th, 2009, 10:43 PM   #3
Tab
Tab's Avatar
I think theres only one carrier for the 14 bolt. You just get the thick ring gear for it. Also, you are the one he got this axle from. The one Ironman and I came and got a few months back. We coulda saved some time if we just got it then
Old June 18th, 2009, 06:31 AM   #4
bearlys2005
Yeah that would have saved time and money for sure... And from what I've found out their are two carriers one for 4:10 and numerically lower and 4:56 and numerically higher. You are also correct, you can get a ring gear that will accept 4:56 and up that is setup to bolt to the 4:10 and lower carrier.
Old June 18th, 2009, 10:54 AM   #5
lt1yj
PM sent.
The carrier was "sold" at the time to a guy on Pirate who never came through otherwise I'd have been happy to have sent it on with the axle.
If you need stock 14 bolt disk brake brackets and the 4 bolt flange welded to the axle I could make you a hell of a package deal
I'm cutting up that 2001 dually axle and taking it to the scrap yard.
Old September 1st, 2009, 02:59 PM   #6
bearlys2005
Could still use a 14 bolt open carrier...
Page generated in 0.18548 seconds with 41 queries
