360 torque sequence - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2009, 09:47 PM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default 360 torque sequence
i believe its an 1989 block ive looked on google and cant find the torque sequence for the heads. is it that important? can i just torque her down to spec or do i have to follow the sequence?
dakotaguy1 is offline   Reply With Quote
Old June 14th, 2009, 10:06 PM   #2
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
start in the center and work your way out. in a Circular pattern. start at like 25#s hit them all, then bump up to like 50#s. and so on
samurai2240 is offline   Reply With Quote
Old June 14th, 2009, 10:07 PM   #3
XXXJ
Desert Rat
XXXJ's Avatar
here you go
Name:	318 torq seq.JPG
Old June 14th, 2009, 10:18 PM   #4
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
thanks guys
Old June 14th, 2009, 11:27 PM   #5
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
is it bad to reuse a couple head bolts? i ordered a new set but a couple are like an inch too long...and i dont know what to do because i think its a 1989 block but its carberated so it prolly has different heads???
Old June 14th, 2009, 11:44 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you got a set for that engine then the bolts all should go in somewhere. idk chryslers but chevys have 3 different length bolts for the heads.
Old June 14th, 2009, 11:55 PM   #7
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
there all there but 5 are too long??? did ARP F'up? how can i tell if i have w-2 heads?
Old June 15th, 2009, 07:45 PM   #8
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
actually four are longer then the others two of the four are to long to use two of them i can use idk. so is it bad to reuse 2 of the old bolts?
Old June 15th, 2009, 07:47 PM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
on a stock engine it won't hurt it
Old June 15th, 2009, 07:51 PM   #10
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
alright thanks
Old June 15th, 2009, 07:57 PM   #11
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
No, they should not be used.
Head bolts stretch over time and use. Reusing them will lead to more issues down the road. Temp fix, fine. To leave it like that is not good.
Old June 15th, 2009, 08:00 PM   #12
Freak
Wheelin the HD
Freak's Avatar
Its 50/50 ... Alum heads cast block no, but Ive seen them successfully reused on motors of the same material, since the stretch is less.
Old June 24th, 2009, 12:22 AM   #13
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
ok so one of the rocker bar bolts snapped how screwed am i?
Old June 24th, 2009, 12:45 PM   #14
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
ahhh yess this happened to me. Take the head off , drill a hole and use an EZ out.... reinstall head. Buy all new rocker bar bolts.
Old June 24th, 2009, 06:41 PM   #15
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
alright thanks. do you know the torque specs for them i printed a sheet off the internet and it says 30ft lbs
Old June 24th, 2009, 10:53 PM   #16
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
That sounds about rite
http://crazy4cars.net/showthread.php?t=1895
sooo yes 30 lol
Old June 28th, 2009, 09:04 PM   #17
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
ok so i was talking with my neighbor and he said i might have to use new head bolts and head gasket when i take that head off is that true head is torqed down. he said he wasnt sure tho because the engine hasnt been ran yet
Old June 29th, 2009, 01:17 PM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I re used my head gasket as it wasn't ran. No issues...also I used the same head bolts.
Page generated in 0.26412 seconds with 78 queries
