Wanted series 2 3800 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2009, 08:43 PM   #1
Buford
Buford's Avatar
Default Wanted series 2 3800
looking for a series 2 3800 for just need the motor no need for the accesorys
Buford is offline   Reply With Quote
Old June 15th, 2009, 11:29 AM   #2
bigyj
bigyj's Avatar
What years would that be. I have a great running 96.
bigyj is offline   Reply With Quote
Old June 15th, 2009, 07:44 PM   #3
Buford
Buford's Avatar
that should be a series 2 how much are you asking for it?
Old June 16th, 2009, 11:11 AM   #4
mtx410
Send a message via AIM to mtx410
what condition? i've got a rebuildable one sitting on a stand right now... it runs, but spun a bearing.
mtx410 is offline   Reply With Quote
Old June 16th, 2009, 06:33 PM   #5
Buford
Buford's Avatar
no I'm lookin for one i can just throw in the car and go thanks tho
Old June 25th, 2009, 08:45 PM   #6
Buford
Buford's Avatar
bump
Old June 26th, 2009, 10:14 AM   #7
What year and make. They are different depending on year.
Old June 27th, 2009, 08:26 AM   #8
mtx410
FYI - they're not different from year/make. any series II will work in any car that came with a series II. doesn't matter if it was a grand prix or a bonneville, or a buick, etc...
the only thing that was different were the "bolt-ons" (accessory mounts, motor mounts). Everything that's different can be swapped over from the old motor. I just replaced one from a '98 bonneville with a newer one from a '03 regal. IDENTICAL.
btw - series II = 1996 - 2002 '03+ gets a little questionable. some cars still had the series II but some started phasing in the series III (they have an aluminum upper intake)
Last edited by mtx410; June 27th, 2009 at 08:29 AM. Reason: added years which used series II
Old June 27th, 2009, 11:09 AM   #9
If you say so. Wiki and I disagree. Bad idea to put a L36 or L26 bottom end in a car that was a L67 or L32. That's why I need to know what year and model ie supercharged or not.
http://en.wikipedia.org/wiki/Buick_V6_engine
The blocks look the same though
Old June 27th, 2009, 01:47 PM   #10
gatesboy
i have 2 one has a bad intake and the other the plentum is bad could be fixed simply make an offer on one or both you can call me for details if you want 269-506-4710 thanks Scott
gatesboy is offline   Reply With Quote
Old June 28th, 2009, 06:56 AM   #11
mtx410
feva, i'd like to know exactly what you found that disagrees with anything i said? if anything it confirms it. we're talking series II (L36) NOT series III (L26). and there was no mention of a supercharger. i'm not sure why you feel the need to go digging up information that doesn't apply to the situation... you may as well tell us how the Ford 3.8L won't work. He's not looking for a "block", he's looking for an engine that will drop right in. Why even post if you're going to be a dick.
Old June 28th, 2009, 07:10 AM   #12
Not being a dick, original poster never specified supercharged or not which is why I asked my original question. Put a 9.5-1 comp ratio motor where a 8.0-1 used to be and let me know what happens.......
You assumed he needs an L36 and then get all butthurt when I give correct information for the given situation while trying to find out if he needs a L67 or L36, who's being the dick?
Old June 28th, 2009, 12:45 PM   #13
Buford
Buford's Avatar
yea i'm looking for a L36 it's going in a 97 LeSabre has a bad knock I'll give you a call tomorrow scott only will will need on engine the one with the bad plenum(guessing the egr tube through it melted)
Old June 29th, 2009, 10:12 PM   #14
beedle4
beedle4's Avatar
Brand new 900
http://detroit.craigslist.org/pts/1245868198.html
Page generated in 0.36239 seconds with 65 queries
