30 amp service for RV's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2009, 11:33 AM   #1
84ramcharger
sim sim balla bim
84ramcharger's Avatar
Default 30 amp service for RV's
I have family coming in 2 weeks and they are going to stay in my fifth wheel for the week. I want to run a 30 amp plug so that they can run anything they want in the camper and not have to worry about popping breakers. o my question is how do I go about hooking this up, I have 2 open breakers in a seperate box outside which used to go to my barn. So how do I split this to make it a 30 amp? Do I need to buy new 30 amp breakers? Any help would be appreciated as I have no idea and do not want to kill myself or burn anything up in the camper in the process of doing this.
Thanks
84ramcharger is offline   Reply With Quote
Old June 13th, 2009, 12:09 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
it is just 120v 30a so all you need is a new 30a breaker and 10 gauge IIRC wire with the correct plug
Old June 13th, 2009, 12:10 PM   #3
You say you have two opne breakers in a box. Do you mean that you have a panel, with two open spots, or you have two breakers in there, that are 15 or 20 amp, and aren't wired to any circuit?
If you have empty spots, just install 30 amp breakers, otherwise, pop the smaller unused ones out and snap in correct sized ones.
Of course, verify that your panel, and whatever is feeding in, isn't overloaded when you add this.
Old June 13th, 2009, 12:11 PM   #4
Yep, 10 gage
Old June 13th, 2009, 12:22 PM   #5
84ramcharger
sim sim balla bim
Yes, I have a box outside that has two breakers installed into the panel already but are not hooked up to anything. They both have 100 on them, does this mean what size amp they are? Also, a 30 amp RV plug has three prongs should I seperate the breakers to 2 15 amp and 1 neutral to make the 3 connections?
Old June 13th, 2009, 12:40 PM   #6
Jeepaholic
Jeepaholic's Avatar
yes that means 100 amp so you will want to remove them. you will only need one single 30 amp breaker. three prongs are; a hot (black) a neutral (white) and a ground (bare copper)
black to the 30 amp breaker, white to the neutral bar and the ground to the ground bar which sometimes is the same neutral bar.
Old June 13th, 2009, 12:53 PM   #7
84ramcharger
sim sim balla bim
That seems easy enough. Just wasn't sure with the three prongs ya know, makes me think 220. But like I said I have know idea what i am doing, I know enough to be dangerous lol
Page generated in 0.19934 seconds with 43 queries
