how does the 5.2 pull? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2006, 10:50 PM   #1
Blackjackbender
Default how does the 5.2 pull?
Well this winter im hoping to have enough money to buy a 95-98 ram 1500. Im not going to be towing a ton with it but occasionally I will. I know its gonna be a bit underpowered but plan on getting a trailer with dual brakes, make sure the trucks brakes are perfect. I would rather have a 5.9 gasser but was wondering how a 5.2 would do pulling a 6000lb trailer and car/truck?
also how good are these engines usually good to?
Old June 14th, 2006, 10:58 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
A 318 will pull any damn thing you want. And run 20000 zillion miles. Literally. My dads 94 ram has 180k on it, not a damn problem
Old June 14th, 2006, 11:00 PM   #3
Blackjackbender
good to know. Ill probably end up holding out for a 2500 5.9 gasser but who knows.
Old June 14th, 2006, 11:28 PM   #4
Mclovin
"The Situation"
Mclovin's Avatar
noodles on here has a 94 wit 318 as well it pulls like crazy. lots of power... he hauls old ass tractors on a regular basis nd i know those things are heavy !1
Old June 14th, 2006, 11:38 PM   #5
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
318's only have 15-20 HP less and 30 ft lbs less than a 360.
I personally prefer the 360 though...hehe.
Old June 15th, 2006, 02:55 PM   #6
Mclovin
"The Situation"
Mclovin's Avatar
Read around a couple people on here i know have said they dont like the 360 because of gearing options..
Old June 15th, 2006, 04:57 PM   #7
GreaseMonkey
Pew pew!
Gearing options? I have 4.10's from the factory.
Old June 15th, 2006, 08:47 PM   #8
Mclovin
"The Situation"
Mclovin's Avatar
Yea i duno the thread but they were bitching that with one gear set it was shifting in and out of OD constantly and with another it just was too high RPM's yea i duno.. but i just drove an 02 with the 4.7 it was nice.
Old June 15th, 2006, 09:00 PM   #9
Jms01dodge
Jms01dodge's Avatar
mine pulls fine but the only thing i pulled was a quad tralior
Jms01dodge is offline   Reply With Quote
Old June 16th, 2006, 08:15 AM   #10
SS
Bananarama!
SS's Avatar
1995 Dodge Ram 1500 5.2L here
Towed a 83 Ford F-250 High Boy no problem. Those old fords are built like tanks too. At least 6000 pounds.
-Jer
Old June 25th, 2006, 11:18 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
My buddy has a '01 1500 4x4 ext. cab with a 5.2L tows his 30' fifth wheel no problem. His camper probably weights 7000lbs dry.
Old June 30th, 2006, 07:13 PM   #12
Kawierider
Kawierider's Avatar
My parents have a 2000 dodge ram van with a 318, before that we had like a 96 with the same motor.
We routinely pull a 28 foot travel trailer with it
I have pulled my Cherokee on a HEAVY ass uhaul trailer behind it. easily more than 6000 lbs.
It has factory 3.73s (or something slighyly lower) in the rearend. It is no cummins, but it has pulled that travel trailer through the mountains numerous times and to south dakota and back, and around lake huron, and through the UP, and to florida, and to Texas, and numerous trips up north with NO trouble.
The only thing we do is turn of the OD ( per the manual) when we tow, keep or speeds down for safety, and run the tow packages with an auxillary trans cooler. Going up some of the bigger inclines it sometimes gets a bit hot, and takes some downshifting and pedal to the floor to make it to the top, but we've never not made it to the top either ( and those were some LONG, STEEP mountains)
It will do just fine just be smart, use weight distribution and good brakes. It pulled my cherokee just fine but stopping that uhaul trailer with surge brakes (in the winter, during a snowstorm) was scary.
***edit--just reread the original post. you want to tow a 6000lb trailer AND a vehicle?! thats over 10,000lbs of trailer, plus gas, consumables, people, fluids, tools etc. I would NOT advise that unless you have a well equipped one ton, not only for power to move but for safety as well.******
Page generated in 0.24327 seconds with 59 queries
