94 Cummins Ram with FASS bypass lift pump? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2009, 12:19 PM   #1
DUNE JUMP
DUNE JUMP's Avatar
Default 94 Cummins Ram with FASS bypass lift pump?
My Dad's cummins has the FASS fuel system, which should easily replace the stock lift pump. The stock lift pump is leaking, and not really needed. Can we just remove it and plate off the hole to bypass the lift pump entirely?
Old June 14th, 2009, 11:31 AM   #2
mudbillyredneck
mudbillyredneck's Avatar
I wouldnt...but what do I know
mudbillyredneck is offline   Reply With Quote
Old June 16th, 2009, 07:06 PM   #3
mprmn08
mprmn08's Avatar
you can but if its just leaking fuel then bypass it and leave it on incase you need it sometime for emergency. just plug in the inlet and outlet so nothin gets it.
Old June 16th, 2009, 07:21 PM   #4
XXXJ
Desert Rat
XXXJ's Avatar
Isn't that a 12 valve with a mechanical pump?
Old June 17th, 2009, 07:02 PM   #5
mprmn08
mprmn08's Avatar
yes it is and a 94 is a 12 valve.
Old June 17th, 2009, 07:22 PM   #6
XXXJ
Desert Rat
XXXJ's Avatar
Let rephrase, that has a mechanical fuel pump, runs off the cam?
Old June 17th, 2009, 07:24 PM   #7
mprmn08
mprmn08's Avatar
yes you are correct.
Old June 17th, 2009, 07:25 PM   #8
mprmn08
mprmn08's Avatar
also FWIW alot of people just feed the mech. pump with the fass system just so if there fass goes out they still have the mech. pump to get them home. the fass will push through the mech. pump also.
Old June 17th, 2009, 07:27 PM   #9
XXXJ
Desert Rat
XXXJ's Avatar
it might be getting too much pressure from the FASS.
I'd replace the mechanical fuel pump and sell the FASS.
Just me, the mechanical fuel pumps on those are uber reliable, unlike the POS carters on the 24 valve VP(mine).
Old June 17th, 2009, 09:51 PM   #10
DUNE JUMP
DUNE JUMP's Avatar
we're pretty happy with the FASS, it is a nice system. Ended up just replacing the 75 cent o-ring on the pump and she's not leaking anymore. I was weary of plugging the inlet and outlet of the mech pump because it's still "pumping" and wouldnt have anything inside to pump, might get hot, bind up, etc.
The FASS puts out 15psi max fuel pressure, so it shouldn't be affecting the mech lift pump, but who knows.
Thanks for the responses
Page generated in 0.17567 seconds with 53 queries
