454 WILL NOT START help please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2009, 10:37 PM   #1
peanutboozer
LET IT SNOW
peanutboozer's Avatar
Default 454 WILL NOT START help please
I've got a 99 K 3500 with a 454 in it. I have spark, gas, 148 ponds compreshin. But the plugs are wet when I pull them. if you turn the key to start it, it sounds ok but will not start. when you turn the key back to run it daesls some times. some times 0 time some times 3 or 4 times. the motor has like 20,000 on it. take to me eny help is good help.
thanks Chris
peanutboozer is offline   Reply With Quote
Old June 10th, 2009, 10:40 PM   #2
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
bad gas?
pyrowaves is offline   Reply With Quote
Old June 10th, 2009, 10:49 PM   #3
Fuel Fire Desire
Mall Crawler
Fuel Fire Desire's Avatar
You dont even own this thing anymore and its STILL giving you ulcers.
The motor may only have 20k on it, but remember, all the sensors and injectors still have 200k on them. Crank position sensor maybe? Any codes at all?
Fuel Fire Desire is offline   Reply With Quote
Old June 10th, 2009, 10:57 PM   #4
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Better question is it carburated, tpi, tbi, or efi; if its carburated, here your case.....
it sounds like your first problem is your carbuerator, has the motor been sitting for awhile??? Your plugs being wet comes from either your float(s) in your carb not being set right or your simply pumping it way more than needed to start. It deisels because your in need of a needle and seat, the needle (I believe) has prolly a groove from sitting or is just in need of a change. Next off is the timing, it may be off on the distributor, and needs tweaking.
Bad gas i believe would allow the motor to run but very poorly, might want to take a gander at a new fuel filter also
84ChevyMuscle is offline   Reply With Quote
Old June 10th, 2009, 10:59 PM   #5
pyrowaves
The Boss
pyrowaves's Avatar
Originally Posted by 84ChevyMuscle View Post
it sounds like your first problem is your carburetor, has the motor been sitting for awhile??? Your plugs being wet comes from either your float(s) in your carb not being set right or your simply pumping it way more than needed to start. It deisels because your in need of a needle and seat, the needle (I believe) has prolly a groove from sitting or is just in need of a change. Next off is the timing, it may be off on the distributor, and needs tweaking.
1999 carburetor?
Old June 10th, 2009, 11:01 PM   #6
84ChevyMuscle
BigBoysNeedBigToys
my bad didnt see that disregard that
Old June 10th, 2009, 11:02 PM   #7
pyrowaves
The Boss
pyrowaves's Avatar
no biggie I had that in mind at first too seeings how I have a 1970's 454. hehe.
Old June 10th, 2009, 11:06 PM   #8
84ChevyMuscle
BigBoysNeedBigToys
i still dont think its bad gas, im leaning towards a sensor
Old June 11th, 2009, 05:32 AM   #9
peanutboozer
LET IT SNOW
I was thinking sensor but cam or crank or?
and if it dont run NO coed
Old June 11th, 2009, 10:25 AM   #10
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
did it throw a code the last time it did run? if so then a code scanner will be able to fine out what it is. both the crank and cam sensor can cause a no start. i forget which is more important of the 2.
Old June 11th, 2009, 12:59 PM   #11
peanutboozer
LET IT SNOW
OK up date NEW TPI, CRANK, MAP, O2's, coil, and going to town to buy a cam
Old June 11th, 2009, 03:39 PM   #12
Fuel Fire Desire
Mall Crawler
This thing has had a dead miss that comes and goes like a light switch for years, on BOTH engines (original and the crate). Its definitely a sensor.
Old June 11th, 2009, 09:36 PM   #13
peanutboozer
LET IT SNOW
yep but all most out of sensors. now I've got it started and it runs good as ever (for now) . I'm thinking the nock, maf,and air temp sensor is all that is left. next time I'll start thare. what about the computer? do thay go bad? and injectors can thay be to blame? still loking for a anser Y but for now it is runing.
Old June 11th, 2009, 10:16 PM   #14
Fuel Fire Desire
Mall Crawler
Quick........sell it to someone you dont know!
Old June 13th, 2009, 08:30 PM   #15
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I used to rap on the computor with my knuckles if the engine stumbled then it had a bad board. washboard roads play hell on this.
Yetti
Old June 14th, 2009, 06:44 AM   #16
TanTahoe
TanTahoe's Avatar
Also check your fuel pressuere. The vortec engines dont like to run if the pressure it below a set pressure (50-60 PSI) i forget. Its been a while.
Dont think it will be this but my grandmas truck wouldnt start. getting spark and fuel. Turn out to be the coil was jumping causing it not to run. but she also had a engine light last time she drove it befor it quit.
TanTahoe is offline   Reply With Quote
Old June 14th, 2009, 07:38 AM   #17
tom tom
tom tom's Avatar
ecm ?
tom tom is offline   Reply With Quote
Old June 14th, 2009, 10:20 PM   #18
peanutboozer
LET IT SNOW
the only coed that come up from time to time is P-0134 (O2 bank 1). Some time it has a mis at idlie and if you look at the tip you can see litile black puffs. I'm thinking injetor sticking but 8 injetors are $550. Thats to much to jest try.
but for know its still running. running to good it blu out the mid shift baring today
Old June 19th, 2009, 01:48 PM   #19
peanutboozer
LET IT SNOW
still run but the miss at idle is still thare 2
Old June 19th, 2009, 03:52 PM   #20
Yetti
Yetti's Avatar
just re-reading through, did you ever run any GM top engine cleaner through this engine before? if not I suggest it. I am wondering if its so carboned up its causing the miss.
Yetti
Page generated in 0.38488 seconds with 83 queries
