big bearing 9" backing plates - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2009, 09:12 AM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default big bearing 9" backing plates
need a set of ford 9" big bearing backing plates for the drum brakes. i dont have the backing plates from whoever did the disc swap before i bought the axle and the fucker leaks like crazy without em.
nate4d is offline   Reply With Quote
Old June 10th, 2009, 09:23 AM   #2
Zebrafive
Are you sure you don't just need new axle seals?
Zebrafive is offline   Reply With Quote
Old June 10th, 2009, 09:25 AM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
just had em replaced. there is a gap that the backing plate fills IIRC
Old June 10th, 2009, 09:25 AM   #4
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Or the correct ones? 28 sline vs 31 splines- same seals just leak like a bitch w/ smaller axles.....
Old June 10th, 2009, 09:33 AM   #5
nate4d
Gnarley Davidson
nate4d's Avatar
not sure what ur saying but i have a big bearing housing and big bearing shafts with the correct bearings and seals.
Old June 10th, 2009, 01:42 PM   #6
dhartman
dhartman's Avatar
Default axle
I am running the same axle with no backing plates and it does not leak. My son's leaks like yours and we figured out the bearing is pressed to far on the shaft and will not seal. You shouldn't need a backing plate to get a seal. The seal is created in the tube. I am not a 9 inch expert but this might help. If i'm wrong someone let me know.
dhartman is offline   Reply With Quote
Old June 11th, 2009, 12:10 PM   #7
Zebrafive
Do you have ball bearings or tapered roller bearings?
Page generated in 0.20643 seconds with 44 queries
