f-150 leaf springs???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2009, 12:01 AM   #1
red347lx
red347lx's Avatar
Default f-150 leaf springs????
i would like to put stronger leaf springs on my truck, it seems to sag alittle in the rear end. would f-250 springs would be a direct bolt on for my truck. Or what would you guys do to correct the problem? any help would be greatly appreciated thanks
red347lx is offline   Reply With Quote
Old June 10th, 2009, 11:34 AM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
they should bolt in, but first do you need the load capacity of the 3/4 ton springs? it will ride rougher, it may be just your springs are weak, and a set of replacement 1/2 tons from another truck would be a cheap fix
broncobuddha is offline   Reply With Quote
Old June 10th, 2009, 11:50 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
yes the 3/4 and 1 ton springs will bolt in
some F-150s had 2.5" springs, so just upgrading to a 3" 1/2 ton might net some gain if that's the case
Old June 10th, 2009, 10:02 PM   #4
red347lx
red347lx's Avatar
thanks fellas
Old June 11th, 2009, 09:30 PM   #5
TurdBronco
easier to put in an add a leaf.
Page generated in 0.17160 seconds with 38 queries
