3/4 ton - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2009, 12:58 AM   #1
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Default 3/4 ton
This might be a dumb question that i should prolly know the answer to but if i were to want and take the k10 in my aviatar photo and swap in a 14bff and d44 what what i need to change. I know that my bolt pattern is going to change, emergency brakes etc. more less wondering about my suspension, is it a direct swap or what???
84ChevyMuscle is offline   Reply With Quote
Old June 10th, 2009, 05:51 AM   #2
Disturban
Disturban's Avatar
Why would you want to swap in a D44? The 10bolt is just as strong! As far as the 14bolt in the rear that would be a good swap. In the late '80s and into the '90s, GM had some light-duty six-lug 3/4-ton trucks that came with a semifloating 9.5-inch ring-geared version of the standard 14-bolt axle with a 6x5.5 lug pattern that is a direct bolt in except u joint and E brake cable. Conversion U-joint is available Precision U-Joints, PN 447. This would be the easiest swap as everything is bolt in and go if you want to swap in a 14b ff I think you will need to move spring perches and change drive shaft length.
Old June 13th, 2009, 09:25 AM   #3
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
As long as you find the same year or close to it, should bolt in but your gonna need new u bolts and and conversion u-joint. Thats what i had to do when the owner before me put the 14ff in.
Page generated in 0.14046 seconds with 32 queries
