Speedo stopped working - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2009, 10:24 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Speedo stopped working
So i was driving the other day and the speedo started bouncing and then just stopped. Also the millage stopped to. Is it the plastic gear that come out of the t-case that went bad or you think it could be something else. A couple people told me to check the gear first. Is that a good place to start?
Old June 9th, 2009, 11:11 PM   #2
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
What type of truck we looking at????
84ChevyMuscle is offline   Reply With Quote
Old June 9th, 2009, 11:15 PM   #3
OldSailor
AKA GreyShrink
OldSailor's Avatar
It would help to know what make and year of vehicle you're talking about.
If it is an older one that has a rotating speedometer cable running from the tranny or t-case to the speedometer head. that cable is usually the first suspect. Often, they will first start to unravel at a certain spot, causing bouncing of the speedo needle. When it eventually breaks, speedo needle movement stops.
OldSailor is offline   Reply With Quote
Old June 9th, 2009, 11:20 PM   #4
84ChevyMuscle
BigBoysNeedBigToys
ive also had it where the cable must have been weakend and snapped going into the gear
Old June 10th, 2009, 08:37 AM   #5
Hoss Blazer
!SPARTY ON!
Sorry 1977 K-5 Blazer w/ 355, Sm465 and NP205. It worked fine last year and wheni put the engine back in it, it started bouncing real low. It would go from 0 to like 10 or 15mph then just stopped worling all together.
Old June 10th, 2009, 05:46 PM   #6
Hoss Blazer
!SPARTY ON!
How hard is that to change? Do you just have to buy a new cable if its that.
Old June 10th, 2009, 11:11 PM   #7
84ChevyMuscle
BigBoysNeedBigToys
yes, you basically just take a measurment for the lenght you need and give that to your local auto parts store, it simply screws into the transfer case and in the dash it just has a locking mechanism that you just pop to slide the cable out be sure not to kink it as it will fail prematurely or not work at all, very simple task
Old June 13th, 2009, 08:14 AM   #8
Hoss Blazer
!SPARTY ON!
Thanks
Page generated in 0.90992 seconds with 47 queries
