leaf spring swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2009, 08:08 PM   #1
Greenmachine96
"Hillbilly Deluxe"
Greenmachine96's Avatar
Default leaf spring swap
will swapping a pair of 1997 chevy silverado Z71 leaf springs fit into a 1996 gmc 1500 suburban? and if so would it give it any more lift cause my stock springs are almost shot.
Greenmachine96 is offline   Reply With Quote
Old June 9th, 2009, 09:36 PM   #2
Ebrown
Ebrown's Avatar
IIRC the burb spring are longer, you could always measure them Center of spring eye to the other!
Ebrown is offline   Reply With Quote
Old June 9th, 2009, 09:43 PM   #3
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
They'd fit, but you'd have to do some fabricating
It really wouldn't be worth your time though, unless they're 3/4 ton springs, a burb is a lot heavier than a truck in the ass end, 1/2 ton springs will sag really quickly. you'd do better to at least but an overload spring in or an add-a-leaf
Lift wise, yes it give you stock lift....for a couple months
wave_crusher is online now   Reply With Quote
Old June 9th, 2009, 10:21 PM   #4
Ebs
Cut the spring eyes off the Z71 main leaf and put it in the Suburban spring pack like an add-a-leaf.
Old June 10th, 2009, 06:14 AM   #5
Disturban
Disturban's Avatar
As stated before Burbs are a lot heavier in the ass end, I would swap in some 3/4 ton truck springs or look for a good set of Suburban springs. I think the 1/2ton Burb springs have one more leaf then 1/2ton truck springs, I could be wrong but I dont think I am. My 3/4ton Burb has 8 leafs in my spring pack. Another option would be to use 1/2ton truck springs and have a leaf added...AB Spring Service Inc in Grand Rapids does this type of work, they can also get you stock replacement springs. They do great work on all suspension and steering related components at a reasonable price. They might even be able to repair your old springs by adding a leaf or something?
4537 Roger B Chaffee Se, Grand Rapids, MI 49548-7506
Contact Phone: (616) 534-3399
This is actually not too bad of an idea!
PS: What ever you end up doing (DO NOT) reuse old U bolts, get new hardware!!!
Old June 11th, 2009, 07:24 PM   #6
Greenmachine96
"Hillbilly Deluxe"
so would it be more usefull to get the 3/4 ton leafs or get an add a leaf. and if i did either of them would they be hard to put in the add a leafs and how much would it cost to put in the 3/4 ton leafs. thanks for the help
Old June 12th, 2009, 01:52 AM   #7
Disturban
Disturban's Avatar
Call AB spring! Contact Phone: (616) 534-3399
Tell them your situation. They might even have some good used springs? They are good people and will help figure out your best solution for the cheapest price.
Old June 12th, 2009, 08:49 AM   #8
bluecrew
-not your friend.
Shouldn't cost too much to swap springs. I swapped some 3/4 ton springs into a 95 Z71 a while back. Went to a salvage yard and they torched the rears outta a 3/4 ton. I think I paid like $50 for the pair. Cheaper than buying lift springs... Just bought new u-bolts and go.
Leaf springs are crazy easy! Hardest part is physically moving them...
bluecrew is offline   Reply With Quote
Page generated in 0.53381 seconds with 47 queries
