Duramax bolt pattern - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2009, 08:02 PM   #1
Disturban
Disturban's Avatar
Default Duramax bolt pattern
Will a Duramax bolt up to a TH400 bell housing? If not do they make adapter plates for the swap?
Old June 9th, 2009, 03:27 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
as quoted from diesel power
"For decades, every Chevy V-8 (with the possible exception of the Indycar engine program) has shared the same six-bolt transmission-to-engine bellhousing-pattern designed for the original 265ci small-block Chevy engine back in 1955.
The upside to this commonality has meant that all Chevy V-8 engines; small blocks, big blocks, 90-degree 4.3L V-6 engines, 6.2L and 6.5L diesels, LT-1, LS1, 8.1L, and even the 6.6L Duramax will all bolt up to the same transmissions. This has helped make Chevy engines the most popular engine to swap into other vehicles."
Old June 9th, 2009, 04:50 PM   #3
PavementPounder
PavementPounder's Avatar
Before you go there, make sure your axle gearing is going to support the rpm's the motor will be running at without an overdrive.
Page generated in 0.22146 seconds with 32 queries
