Clanking/Rattling Noise from rear of truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 6th, 2009, 12:34 AM   #1
94transam25th
94transam25th's Avatar
Default Clanking/Rattling Noise from rear of truck
Ok i have a clanking/rattling noise that sounds like it is coming from the rear on my truck that is driving me crazy and i cant seem to figure out what the hell it is. It only happens when going over bumps
Anyone got any ideas i was thinking Ujoint but dont know how to check
thanks in advance,
Brandon
94transam25th is offline   Reply With Quote
Old June 6th, 2009, 12:49 AM   #2
MilwaukeeF350
Dan
First quick question
is tailgate tight to bed? That what I would check because they get loose then make those noise what you describe. Does it make noise when it hit bump road?
Old June 6th, 2009, 09:26 AM   #3
94transam25th
yea my tailgate is kinda loose and i cant really find and adjustment to tighten the latches, or do they sell the rubber bushings at the dealer?
btw the truck is a 2000 silverado 1500
thanks
Old June 6th, 2009, 09:49 AM   #4
scottie
Eye candy
scottie's Avatar
Spare tire loose?
Old June 6th, 2009, 10:07 AM   #5
94transam25th
nope checked the spare tire and its tight... i think im gonna take it down anyways no point carrying a 31" spare running 35's lol
Old June 6th, 2009, 10:29 AM   #6
94transam25th
it sounds like its coming from my rear diff... i pulled the back wheels off and when i move one i hear what i think is the clank noise im hearing when driving, how screwed am i? is the slack fixable or do i need to get my rear diff rebuilt?
Old June 6th, 2009, 09:15 PM   #7
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Sounds like the outer pinion bearing is going/gone
Old June 6th, 2009, 09:37 PM   #8
Swampdog02
Wakley Creek Wacos!
Swampdog02's Avatar
GM had to replace one of them (Pinion Bearing) on my 2000 on their dime with about 40K on it.
I dropped it off at the Dodge Dealearship on the second one, and they turned it into a 2004 Hemi for me. (86K on it that time)
Good Luck.
Swampdog02 is offline   Reply With Quote
Old June 7th, 2009, 12:12 AM   #9
Woodyjiw
FUCK CANCER!!!
Woodyjiw's Avatar
Does it have a rear sway bar on it, if so check the sway bar links they will go bad and make noises over bumps.
Woodyjiw is online now   Reply With Quote
Old June 7th, 2009, 09:38 PM   #10
94transam25th
well i am an idiot... the noise i heard when spinning the one side was the rotor on the other side hitting the stud so when i put the wheels back on and did it there was no noise lol... i still have that rattle so im thinking it could be the tailgate
Old June 7th, 2009, 09:55 PM   #11
luvitmyjeep
broken
luvitmyjeep's Avatar
heat sheild.
luvitmyjeep is offline   Reply With Quote
Old June 7th, 2009, 10:03 PM   #12
94transam25th
heat shield where? on the brakes?
Old June 7th, 2009, 10:06 PM   #13
MilwaukeeF350
Dan
It on exhaust I am not good with spell it cat converter.
I heard 1 guy that replace aluminum driveshaft with steel driveshaft it stop make noise.
Have you try raise on car hoist or jack rear axle off ground then have someone in driver to spin tires so you could listen where noise came from.
It useful for me but keep mind it kind dangerous but make sure you have 2 jack support that can hold weight and on cement.
Old June 10th, 2009, 04:12 PM   #14
wave_crusher
I'll Direc your TV
I don't know what kind of chevy truck you drive that has a rear sway bar....unless it was a burb or tahoe that you cut the top assend out of it
Old June 11th, 2009, 08:28 PM   #15
SammySmalls
SammySmalls's Avatar
E-Brake cables!
SammySmalls is offline   Reply With Quote
Old June 12th, 2009, 07:52 AM   #16
bluecrew
-not your friend.
I'd pull the tailgate off and see if the sound is still there. IIRC, those trucks clunk in hte rear end when shifting... Had them before, myself...
bluecrew is offline   Reply With Quote
Page generated in 0.34494 seconds with 71 queries
