home wiring - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 5th, 2009, 11:32 AM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default home wiring
i dont think this right thus im ask i have both neutral and earth grounds going to ground bar
Old June 5th, 2009, 11:34 AM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
after the first means of disconnect all neutrals and grounds have to be separated. If service goes right from the meter to the main panel, then inside that panel all neutrals and grounds attach to the same bars. If you have a fuse able disconnect in between the meter and main panel, then you must isolate the neutral bar
Old June 5th, 2009, 11:44 AM   #3
unclebeaner
goes right from meter to panel so im fine correct?
Old June 5th, 2009, 11:47 AM   #4
the harvester
the harvester's Avatar
correct
the harvester is offline   Reply With Quote
Old June 5th, 2009, 11:49 AM   #5
unclebeaner
horray
Old June 5th, 2009, 12:25 PM   #6
Cooter21
Im Rick James Bitch
Cooter21's Avatar
Way to hit it CC.
Cooter21 is offline   Reply With Quote
Old June 5th, 2009, 12:32 PM   #7
chevotass
chevotass's Avatar
im neutral
Old June 5th, 2009, 12:50 PM   #8
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
Black wire is neutral correct?...................
Red68Camaro is offline   Reply With Quote
Old June 5th, 2009, 12:53 PM   #9
unclebeaner
why does it need to be about color now?
Old June 5th, 2009, 12:54 PM   #10
Red68Camaro
I'm color blind......
Old June 5th, 2009, 01:02 PM   #11
Slayer63
Upstanding Member
Slayer63's Avatar
green is gound the world around
Slayer63 is offline   Reply With Quote
Old June 5th, 2009, 01:06 PM   #12
clarkstoncracker
lol
you must never dabble with PLC systems
Old June 5th, 2009, 01:30 PM   #13
itselliott
itselliott's Avatar
word
Old June 5th, 2009, 01:43 PM   #14
the harvester
or automotive
Old June 5th, 2009, 02:17 PM   #15
Slayer63
Upstanding Member
Slayer63's Avatar
Originally Posted by the harvester View Post
or automotive
he said home wiring.
Page generated in 0.22124 seconds with 67 queries
