Stupid effing oil pans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 4th, 2009, 05:27 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default Stupid effing oil pans
I love to do an oil change. After wiping the pan down to clean up all the drop of oil on it. Then find out the oil just keep coming out the side of the pan. Grrrrr. Bring on the break clean, wire brush and JB weld. Oh and cross fingers.
Old June 4th, 2009, 06:35 PM   #2
BooGTS
Boost Withdrawl
BooGTS's Avatar
been there, cept on this car it was easier to just remove and reinstall umpteen bolts.
BooGTS is offline   Reply With Quote
Old June 4th, 2009, 06:41 PM   #3
Bishop
Bishop's Avatar
yeah i have replace a couple pans from oil seeping through the rust.
what is it on?
Old June 4th, 2009, 07:37 PM   #4
4Bangler
Jackstand Wheeler
4Bangler's Avatar
I worked with a surveyor that had (2) oil pans rust through in the course of 1 year, the first one I understood, it was 15 years old at the time, then he bought a factory replacement, and it didn't even last a year, rotted and actual hole in the side, he took it back and they said to buy an aftermarket one....stupid Ford guys....he ended up welding a patch on the original.
Old June 4th, 2009, 08:54 PM   #5
Fatty Matty
Fatty Matty's Avatar
I pulled the oil pan off of my wrecked volvo the other day.
Cast aluminum and about 28 bolts holding it on.
'12 JKU
'14 1500
www.midwest-abs.com
Fatty Matty is online now   Reply With Quote
Old June 4th, 2009, 08:56 PM   #6
Freak
Wheelin the HD
Freak's Avatar
had to drop the pan on my 2wd F150 with the 300Y god that was a lot of bolts... leaked 3 days after I put the new seal on too.
Old June 4th, 2009, 09:04 PM   #7
Trendsetter
Trendsetter's Avatar
Send a message via AIM to Trendsetter Send a message via Yahoo to Trendsetter
be glad you dont have 3208's... they are hard to come buy for replacment and they cost around $600 on up.. and they ALL rust out!!! just replaced one on my boat...
Trendsetter is offline   Reply With Quote
Old June 4th, 2009, 11:30 PM   #8
Yota Bill
pulled the engine on an 05 F250 diesel and resealed several points, oil pan being one of them...couple days later, oil pan leaking again, could see it running from the back corner of the pan, down the hump around the crank, and dripping off roght there...removed the pan, cleaned off the sealant, and resealed it, without pulling the engine...still leaked...then I found out about a small o-ring on the injection pump that would leak oil, run down the lifter valley, and drip off between the trans and engine, making it look like the oil pan...checked that, and about 15 minutes later had the leak fixed...that sucked...
Old June 5th, 2009, 12:04 AM   #9
Shotgun
Shotgun's Avatar
what is it on?
95 saturn sc2
Old June 5th, 2009, 12:24 AM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
I've lived that dream before. Turned out to be an oil line going from the injection hydraulic pump to the cylinder head (Powersmoker). I thought it was a bad main seal because it was leaking into the bellhousing of the trans instead of on top of it.
Old June 5th, 2009, 12:24 AM   #11
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
2000ish S10 Blazer 4x4's are stupid. We had to pull the pan to check the oil pump on my friend Justins.
The book calls for pulling motor mount bolts, and the front differential bolts to push it out of the way as much as possble.
I will never own a new car.
Old June 5th, 2009, 08:43 AM   #12
Mikey1258
HAND-ME-DOWN Racing
Mikey1258's Avatar
Location: Muskegon Mi. http://www.mymudlife.com/profile/MIkeyWells
Send a message via Yahoo to Mikey1258
got a 351 w/same issue....u would think it would atleast stop rusting...but ya know what they say...on a quiet night you can hear a ford rust!
Mikey1258 is offline   Reply With Quote
Old June 5th, 2009, 08:48 AM   #13
junk90xj
ALLPRO AUTO
junk90xj's Avatar
try a product called seals-all. it works great for rust holes in oil pans.
http://www.apalansing.com/
Page generated in 0.29163 seconds with 61 queries
