14Bolt FF for SF swap? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 3rd, 2009, 09:53 PM   #1
Disturban
Disturban's Avatar
Default 14Bolt FF for SF swap?
Will a 14bolt FF be a direct swap in place of my 14bolt SF on my Suburban? Do they use same U joints, perches, E brake hook up, ect ect? Also is the spring perches from a truck the same width as my Burb?
Old June 9th, 2009, 04:56 PM   #2
PavementPounder
PavementPounder's Avatar
It needs to be from the same generation truck as far as the perches are concerned. U-bolts will be different due to the diameter difference of the tubes. Same for spring plates.
E-brake connections can vary. The one that went into my Suburban had different backing plates, but I found a set off another 14bFF that had the correct cable inputs for my truck's cables.
Old June 10th, 2009, 04:56 PM   #3
Disturban
Disturban's Avatar
What about drive shaft length?
Old June 10th, 2009, 04:58 PM   #4
PavementPounder
I didn't have to change mine from the 14bSF to the 14bFF.
Old June 11th, 2009, 01:03 AM   #5
Disturban
Disturban's Avatar
Alright thanks
Old June 14th, 2009, 11:35 PM   #6
outalne94z71
bouncingtrucks.com artist
outalne94z71's Avatar
the 9.5 and 10.5 must have the same tube diameter , i have a set of the lower 88-98 body style axle plates and they fit either axle perfectly
outalne94z71 is offline   Reply With Quote
Page generated in 0.16595 seconds with 41 queries
