8 bolt D44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2009, 04:14 PM   #1
jeremitaylor
Default 8 bolt D44
I have heard that early 2nd gen (94-95)Rams had a heavy half(or light 3/4) option that had a 8 bolt D44 can anyone confirm this? Would these 8 bolt hubs and matching rotors be able to convert a D44 to 8 bolt (allowing a D70 to be put in the rear!) Please point me in the right direction(no swaps just a work truck)
jeremitaylor is offline   Reply With Quote
Old June 20th, 2009, 09:43 PM   #2
redleg
Here's a start if you haven't seen it. You'll probably have to swap the everything including the outer knuckle.
http://77cj.littlekeylime.com/Mr.N44.htm
redleg is offline   Reply With Quote
Old June 21st, 2009, 08:09 PM   #3
Clay
Fishin' rig
Clay's Avatar
I put a D44 with 8 on 6.5 in my Wrangler, it came from a late 70's Ford 3/4 ton if that helps at all.
Clay is offline   Reply With Quote
Old July 1st, 2009, 10:05 AM   #4
PavementPounder
PavementPounder's Avatar
I have never seen or heard of that. If it even exists, it would be a light 2500. It could be related to the two different GVWR D60 listings, unless it was an export option.
Ask on Pirate in Dodge Tech.
Page generated in 0.24075 seconds with 35 queries
