tbi 350 running weird - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 31st, 2009, 09:17 PM   #1
honda rider
Beaver Patrol
honda rider's Avatar
Default tbi 350 running weird
picked up an 87 chevy 4x4 with a tbi 350 in it runs good idling, but when driving after a few min. it starts to babble and act like its goin to die, found if i turn the key off then turn back on before motor quits it will run fine again for about thirty sec. then start running weird all over again. any suggestions?
honda rider is offline   Reply With Quote
Old June 1st, 2009, 06:38 AM   #2
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
full tune up, cap, rotor, plugs, wires, and o2 sensors. made mine run right
OL RED is offline   Reply With Quote
Old June 1st, 2009, 06:43 AM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
If it is truly resetting and running fine after a key-off situation, I would say the problem lies in the ECM. I had some memory faults in my TPI, and when I sent it to the pcmforless.com people, they found the fault, reburned a module for my modifications, I pulled out another ECM from the junk yard, and I've never had a problem since.
Mine would do the exact same thing as yours. It would fire up run a little rough at first (I remember the IAC being very erratic), and if I got into the gas within 2 or 3 minutes it would backfire or die. It would then run ok for 25-30 minutes then it would die again.
The other thing to check is if its going into closed loop. IIRC, 30 seconds is when your engine should start using 02 sensors to modify fuel flow.
Its pretty impossible to troubleshoot that setup without cross count numbers, and the like. Try to find a real-time digital scanner. They have really came down in price over the last two years.
Old June 1st, 2009, 06:52 AM   #4
IFS SUCKS
I like trees
IFS SUCKS's Avatar
pcmforless.com is the shit.
IFS SUCKS is offline   Reply With Quote
Old June 1st, 2009, 08:29 AM   #5
honda rider
Beaver Patrol
prolly cant eleminate any of that can i, truck is strickly off road
Old June 8th, 2009, 10:51 PM   #6
blowngp99
Country Boy
blowngp99's Avatar
Send a message via AIM to blowngp99
I was having the same problem last week. I picked up a set of NGK plugs, and it run's really good now. I would start with the plugs and go from there.
blowngp99 is offline   Reply With Quote
Old June 9th, 2009, 02:04 AM   #7
Disturban
Disturban's Avatar
Mine also ran like that last year and it was the fuel filter. It did not throw any codes so if you have no check engine light start there along with full tune up. Fuel filters are about $15 and easy to change.
Old June 9th, 2009, 07:59 AM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you don't feel like fixing it switch over to a carb. since it's not a dd or on road truck i'm sure you don't care about mileage.
Old June 9th, 2009, 08:02 AM   #9
honda rider
Beaver Patrol
that about that, i got the stuff to convert it over
Old June 9th, 2009, 03:53 PM   #10
PavementPounder
PavementPounder's Avatar
What is it with you not wanting to fix shit?
Old June 9th, 2009, 04:38 PM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
technically he will be fixing it by switching over to a carb. replacing what causes the problem is what most people call "fixing"
Old June 9th, 2009, 10:19 PM   #12
PavementPounder
No, most people who speak English know "fixing" to mean repairing something. "Replacing" something is removing it and putting another identical one in its place.
You are suggesting neither.
Old June 9th, 2009, 10:40 PM   #13
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Guter kluger Arsch hat abgeschlossen that better? lol
Old June 9th, 2009, 10:54 PM   #14
PavementPounder
Good smart ass locked?
Old June 9th, 2009, 11:01 PM   #15
Disturban
Disturban's Avatar
I tellin ya try a new fuel filter first...took me a long time to figure out why mine was running just like yours is. TBI likes about 14psi and if your filter is just a little dirty and it's only getting say 12 psi it will run like shit. Turn it of and some of the contaminants can separate from the fuel filter allowing it to flow better and run good for a little while until they clog the filter again.
Old June 9th, 2009, 11:17 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
f-ing translators. never consistent
Old June 11th, 2009, 08:30 PM   #17
SammySmalls
SammySmalls's Avatar
Crank sensor going retarded, once it warms up the computer adjusts timing and it starts to crap out...
SammySmalls is offline   Reply With Quote
Page generated in 0.41831 seconds with 74 queries
