Can't stop t-case leaking from tailhousing seal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 30th, 2009, 12:15 PM   #1
Ebs
Default Can't stop t-case leaking from tailhousing seal
The slip yoke seal in my truck (push button np243) was leaking so I replaced the seal a few weeks ago and no change, it leaks just as bad.
Any clues whats going on before I try another seal?
Old May 30th, 2009, 12:32 PM   #2
koochman450r
koochman450r's Avatar
yeah check your driveshaft where the seal rides. A lot of time on older trucks the steel on your slipyoke will wear down and your seal will not contact it good enough. If its wore replace it if its not then maybe your output shaft is loose and letting it slop around and wearing seal prematurely.
Old May 30th, 2009, 03:00 PM   #3
rargreen
88
rargreen's Avatar
Is the truck lifted? Incorrect drive shaft length will wear the splines & let the shaft slop around & take out the seal.
rargreen is offline   Reply With Quote
Old May 30th, 2009, 04:55 PM   #4
Ebs
I put an add-a-leaf in the rear about a year ago, so it only sits about 1-2" higher than stock. If the yoke is pulled out a little from that then the seal should be on the fresh clean surface of the yoke that was once further back in the tailhousing.
My thought was that the output shaft has some play in it, I didn't feel any movement when I was changing the seal though. However, when I got the truck I did only find about a quart, if that, in the t-case so who knows what kind of shape the internals are in.
Old May 31st, 2009, 11:52 PM   #5
Ebs
Wow, I read that wrong. Makes sense, more lift = less spline engagement.
Old June 1st, 2009, 01:12 AM   #6
freeballn
that guy
right behind the seal is a bronze bushing. if the bushing is worn out it will allow the slip part of the shaft to cock in the housing and leak fluid.
real common on chevys too.
freeballn is offline   Reply With Quote
Page generated in 0.15773 seconds with 41 queries
