86 Ford Ranger 4X4 Turbo Diesel - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 28th, 2009, 07:13 PM   #1
Keogge
Unhappy 86 Ford Ranger 4X4 Turbo Diesel
Hey all who view this... I recently replaced the Turbo on my pick-up to find that I no longer have fuel going to the injectors. When I turned teh key I would hear a Click and then a secound later another click. I hear nothing now. I thought of by-passing the shut off but it is not like the Toyota engines I am used to. Anyone out there have any ideas? I would rather keep it working with the key than to change the ignition.
Keogge is offline   Reply With Quote
Old May 28th, 2009, 11:29 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Did you have fuel to the injectors before you replaced the turbo? If so sounds like something had to get disconnected or knocked loose. 99.9% of the time there are no cowinsedence(I know that's not close to being spelled right) when you are working on cars.
booblinker is online now   Reply With Quote
Old May 28th, 2009, 11:42 PM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
Electric lift pump?
Old May 29th, 2009, 01:15 AM   #4
Keogge
Thank-you for responding: Yes, there was fuel. It ran real well just no turbo as the blades were burned off. All I did when I removed the Turbo was disconnect the battery. It used to make a Click and then another click followed shortly after when I turned teh ingnition on. Seems to be strange as I went over every wire and connector.
Old May 29th, 2009, 04:51 AM   #5
blizazer
blizazer's Avatar
Send a message via AIM to blizazer
Does that include the battery terminals?
blizazer is offline   Reply With Quote
Old May 29th, 2009, 05:39 AM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
did the battery arch out at all when you took the cables on or off? did you check your fuses? just throwing that out there i had that happen to me ones
Old May 31st, 2009, 08:30 PM   #7
Keogge
The battery is new and so are the post connectors. There was no arch and the fuses are all fine. It is real strange... My Jeep one time was not getting any power to the fuel pump, everythign looked fine then I decided to change out the relays and it worked fine. Gas engine, but if the Ford had relays I would try that as well. I will keep tinkering till I find something.
Page generated in 0.24210 seconds with 44 queries
