Motor trans bolt up?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 27th, 2009, 02:12 PM   #1
PCK_4xCustoms
r00t4r3d
PCK_4xCustoms's Avatar
Send a message via AIM to PCK_4xCustoms
Default Motor trans bolt up??
96 S10 4cyl with 5spd manual 2wd
Will a 4.3l V6 bolt up to this trans by chance??
PCK_4xCustoms is offline   Reply With Quote
Old May 27th, 2009, 02:23 PM   #2
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
will it bolt up -yes
will it hold up - no
Old May 27th, 2009, 02:28 PM   #3
PCK_4xCustoms
r00t4r3d
k what manual trans would work then
Old May 27th, 2009, 03:42 PM   #4
Disturban
Disturban's Avatar
A T5 transmission is what you need. You can find them in any 4.3 liter s10 and also in 3rd gen camaros/firebirds.
Old May 27th, 2009, 07:45 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
idk what anyones talking about. the 2.2 has a totally different bellhousing pattern compared to the 4.3. your truck has the Nv1500. if you put a 4.3 in there your gonna want the 2wd Nv3500. your clutch linkage should be a direct swap as well.
the T5 was only offered with either the 2.2 up to 1995. or the 2.8 up to 1993. the T5 was offered in F-bodies with the 2.8 TBI 305, and TPI 305.
Old May 27th, 2009, 11:36 PM   #6
unclebeaner
wrong 2.2 has the same as 4.3 they both used a 4l60e in later trucks
Old May 27th, 2009, 11:51 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
read this http://members.shaw.ca/betterthanyou...t_patterns.htm
Old May 28th, 2009, 12:05 AM   #8
unclebeaner
funny the small block bolted up to my 4l60 just fine
Page generated in 0.24580 seconds with 47 queries
