No More death wobble, not for sale currently...1993 Jeep Grand Cherokee $2200 obo!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The recycle bin.
The recycle bin. Posts deemed annoying. If you see your post here, take a hint.
Old May 26th, 2009, 02:47 PM   #1
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
Send a message via MSN to xREAPERx9
Default No More death wobble, not for sale currently...1993 Jeep Grand Cherokee $2200 obo!!!
Ok, i have bout had enough with this jeep. Great jeep but the wobble is unberable. Took it to the shop they said its the steering stabilizer shock. Im gona fix it and if it fixes the froblem then i will not sell the jeep.
The Good
318 5.2Lt V-8
148,xxx miles
4.5 inch rough country lift
31x10.5x15 Tires
New Shocks
Starter
Front fenders and hood
Rear doors
ALL NEW TIE RODS, Track Bar & Steering box
The bad.... IT WOBBLES
Take trades on other jeeps.....
ID:	43909   Click image for larger version
ID:	43910   Click image for larger version
xREAPERx9 is offline   Reply With Quote
Old May 27th, 2009, 01:07 PM   #2
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
ttt
Old May 28th, 2009, 10:05 AM   #3
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
ttt
Old May 28th, 2009, 01:38 PM   #4
Ford forever
Bought another jeep
did check b joint and u joint and everything?
Ford forever is offline   Reply With Quote
Old May 28th, 2009, 08:59 PM   #5
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
UPDATE NO MORE DEATH WOBBLE, it was the stabilizer shock.... no longer for sale....
Old May 29th, 2009, 12:52 PM   #6
kmanxj5011
kmanxj5011's Avatar
for now that will just be a band aid ;)
kmanxj5011 is offline   Reply With Quote
Old May 29th, 2009, 01:23 PM   #7
PavementPounder
PavementPounder's Avatar
x2. The only thing a stabilizer does is control the rate at which the steering system can cycle. They aren't even required if you have good alignment, decent positive caster, and no worn components.
You need to keep looking. There is a component somewhere that is f'd up.
Old May 29th, 2009, 01:30 PM   #8
pigfat
GONE COMMANDO
pigfat's Avatar
usually the bolt hole where the track bar bolts to the axle gets wollered out. Check that. Ive seen it many times.
pigfat is offline   Reply With Quote
Old May 29th, 2009, 03:30 PM   #9
redram98
redram98's Avatar
ditto. both the track bar mount at my axle and drop bracket from frame are ovaled. fix those then get the camber checked. does the lift consist of adjustable control arms?
Last edited by redram98; May 29th, 2009 at 03:31 PM. Reason: spelled "ditto" wrong
redram98 is offline   Reply With Quote
Old May 30th, 2009, 08:54 AM   #10
no1mover
article in this issue of jp that discusses this issue.
no1mover is offline   Reply With Quote
Old May 30th, 2009, 09:24 AM   #11
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
x2 to what everyone has said.
*2007 Rubicon
*2006 Duramax
Old May 31st, 2009, 01:18 PM   #12
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
DAAAAAAAA..... everything is replaced.....
Old May 31st, 2009, 03:45 PM   #13
PavementPounder
What additional new parts does it have now?
Old May 31st, 2009, 03:56 PM   #14
HVYRTFT
Reed my teef
HVYRTFT's Avatar
probably triple steering stabilizers
Old June 1st, 2009, 09:00 AM   #15
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
UR A FUNNY GUY
Sorry guys the old lady got on here yesturday, it has new track bar, all new tie rods, steering stabilizer shock, ball joints, sway bar, and steering box.
Old June 1st, 2009, 09:15 AM   #16
ArcticCat843
ArcticCat843's Avatar
Send a message via AIM to ArcticCat843
Did you get a alignment after all that? Did you install everything, drive 100 miles and then re torque ALL the bolts? Where all the bolts torqued down with jeep on the ground? As in so the weight of it compressed the suspension?
Id be willing to bet you have something loose somewhere......Id check it all out again then take it to a GOOD alignment shop.
ArcticCat843 is offline   Reply With Quote
Old June 1st, 2009, 09:28 AM   #17
PavementPounder
Good point. Inverted-Y steering systems require alignments after you disturb any of the steering components.
Old June 1st, 2009, 02:37 PM   #18
xREAPERx9
Swamp Thing
xREAPERx9's Avatar
Yes, and thank you..... got the alignment done imediatly after changing everything....
Old June 8th, 2009, 09:21 PM   #19
C.K.
Dont Feed the Cyco
C.K.'s Avatar
please pm me an address so I can look at the Jeep
C.K. is offline   Reply With Quote
Old June 8th, 2009, 10:26 PM   #20
guest
Send a message via AIM to guest
Hahaha
guest is offline   Reply With Quote
Page generated in 0.34084 seconds with 83 queries
