Michelangelo 2nd gen Explorer SAS - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 1st, 2009, 01:19 PM   #21
fsumotorhead
N8KVB
fsumotorhead's Avatar
Will you be selling your IFS lift kit?
Old June 1st, 2009, 03:00 PM   #22
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
yes i will, when i get back home, also will have a skid for sale, engine, trans, transfer case, 8.8 etc.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old June 1st, 2009, 07:11 PM   #23
pistol pete
I do vinyl stickers
pistol pete's Avatar
awesome looking project, i just want to say thanks for serving our country and protecting our freedom.
pistol pete is offline   Reply With Quote
Old June 4th, 2009, 12:39 AM   #24
thanks alot pete, i really appreciate the compliments!
Old June 9th, 2009, 01:29 AM   #25
deerbowtie is dropping off the rear 60 this sunday..im a happy camper
Old June 15th, 2009, 12:58 AM   #26
axle arrived and is in good shape, im going to clean off the grime and goo, and disassemble the whole thing and paint the housing i decided to weld the spiders until i can find the money for a good locker
also the cover has a few dents in key areas and the fill plug is a little goofed up..
i plan to order a cheapie online for now.
Old June 15th, 2009, 03:35 AM   #27
VonDirt
VonDirt's Avatar
we need pix of these things so ya get the whole before and after effect -
so this is jeff's fault huh ? i can see how that would be - that truggy is supa bad
sounds like a cool build up, looking forward to more
VonDirt is offline   Reply With Quote
Old June 16th, 2009, 02:46 PM   #28
pics on the way soon
ill go take some when i get off the phone
Old June 16th, 2009, 02:49 PM   #29
FordGurl
Go Big or Go Home!
FordGurl's Avatar
Pink bolts?
FordGurl is offline   Reply With Quote
Old June 16th, 2009, 02:55 PM   #30
if you get me the paint :D
Old June 16th, 2009, 02:58 PM   #31
FordGurl
Go Big or Go Home!
FordGurl's Avatar
Whipped already? hahahaha
Old June 16th, 2009, 03:03 PM   #32
if i recall correctly i said i will put pink diff bolts on if you supply the paint.
Old June 17th, 2009, 12:35 AM   #33
this has a dent in it, im pretty sure it was hitting the ring gear.. ill replace it soon
before
more before
sand would have really helped, i might still blast it later but im all out of media
one side, i like the axles silver.
the other stud is soaking in parts cleaner, it is froze to the nut
not bad for one day, i think my wire wheel is about shot after all that
as you can see, i dont like to work far from the fridge which is for sale. LOL
unfortunately i cant throw in the axle until i get back from training so next on the parts to do list is clean up the heads, remachine a valve seat and a mild port job. Also still hunting down the front 60
Old June 20th, 2009, 04:20 AM   #34
i said screw it, and decided not to do this anymore...
kidding, im just having issues with what to run in front. i was suggested coilovers and 3 link because air shocks will fail. if anyone is running that, id really like some feedback on how you like it.
im pretty sold on a rear shock tower that will stick up approximately 14.94" into the body at a 32 degree angle allowing exactly 24" from the axle mount to the body when fully extended, and at full compression should leave 2.99" of clearance...obviously wont EVER flex all that out, so ill throw in a couple bump stops to keep from mangling the sheetmetal. as for a limiting strap, i have come up with a design using a 1 ton ATV winch inside the cargo area between the shock hoops, and fuel cell, the plan is to weld a 1/4" plate to the body itself as re enforcement with a _V_ shaped mount tying into the cage, with a small non roller type fair lead mounted into the floor.
as for pictures of me working, just imagine me staring at my explorer with a measuring tape, protractor, square and laptop marking off lines and plugging them into the computer. its boring as hell.
Old June 20th, 2009, 06:35 AM   #35
Seems like sitting there being confused is where about 75% of the time is spent.
Old June 20th, 2009, 07:47 AM   #36
so true
VISUALIZE!
Old June 20th, 2009, 10:21 AM   #37
95geo
newbie
95geo's Avatar
I can vouch for that...
who is the genious who told you air shocks would fail? I have set up countless air shocks, seen thousands and on my 3rd set myself and the only time I have seen a failure is from topping out (lots of hard jumping) and letting the axles hang off the internal circlip that holds them together. A limit strap will solve that problem.
It takes a lot of time or some good luck to dial in air shocks but once they are there and the suspension geometry is good they will work as good as anything else until you spend hours at speed in the desert.
I will say that if you do the one link like you want that air shocks will only hurt the performance more.
Old June 22nd, 2009, 04:14 PM   #38
will they be alright on with 3 link setup with a good trackbar?
Old June 24th, 2009, 11:35 PM   #39
ILLICIT4x4
ILLICIT4x4's Avatar
You should consider paying me the rest of the money that you still owe me on the truck....
ILLICIT4x4 is offline   Reply With Quote
Old June 24th, 2009, 11:51 PM   #40
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
wtf over.......wheres my fucking popcorn.......
.......ahhh there it is
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Page generated in 0.47045 seconds with 84 queries
