Bronco top bolts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2009, 10:26 AM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default Bronco top bolts
I currently have a 96 full size that the top is held on by security torx bolts. I have snapped 4 bits trying to get these off. I have had other broncos pre 96 and all of the tops were held on by hex bolts. I am considering cutting all of the security torx bolts off and replacing with the pre 96 kit. Does anyone know of any reasons why this would not work. I contact Jeff broco grave yard and they were not sure if it would or wouldn't work.
Silver Bullet is offline   Reply With Quote
Old May 22nd, 2009, 10:29 AM   #2
masterbeatty
masterbeatty's Avatar
my 95 has the same thing and so did my 94. i took a grinder to them and just replaced the clips and bolts. i only use between 3 and 5 bolts. so that should work fine.
Old May 22nd, 2009, 10:29 AM   #3
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
i would give it a shot, you can buy the bolts and clips from broncograveyard, might have to replace clips too
big_ol_bronco78 is offline   Reply With Quote
Old May 22nd, 2009, 10:31 AM   #4
Silver Bullet
all of the broncos i have owened or been in 78,79,85,86,90,91,95,96 all had bolts. My 96 is the first I have seen with the security torx.
Old May 22nd, 2009, 10:31 AM   #5
masterbeatty
autozone or glendale will have the clips.
Old May 22nd, 2009, 10:31 AM   #6
masterbeatty
wow. yea all 3 of myne have. they suck so bad.
Old May 22nd, 2009, 10:32 AM   #7
Silver Bullet
yeah i am replacing both. The kit is like 36 bucks. I just wanted to make sure before i started cutting.
Old May 22nd, 2009, 10:33 AM   #8
Silver Bullet
i think it the stupidest thing I have seen. First you are on an angel because of the glass so you cant put a lot of force on the torx bit or get a good seat in the bolt.
Old May 22nd, 2009, 10:35 AM   #9
masterbeatty
if you get the tox bit with the security hole for a ratchet you could prolly get it. i tried that then said forget it ill just cut em.
Old May 22nd, 2009, 10:46 AM   #10
Silver Bullet
i can get most of the about a 1/4" to a 1/2" up and thats it. I'm just gonna cut them. I like the hex bolts way better.
Old May 25th, 2009, 04:02 AM   #11
Shotgun
I only wheel with boats.
Shotgun's Avatar
get them out as far as you can and cut the head off, remove said top and weld a nut on the the stud and remove with rachet.
Old May 25th, 2009, 11:39 AM   #12
Never_Evil
Auto zone had the dimpled torx that you can put into a ratchet. Made by am-pro and about 15 bux. Harbor freight has them too, but you are dealing with a lesser quality bit and you will need to purchase 5 or 6 sets.
The idea of tack welding on a nut over the torx head is a good idea. You may need to use some muratic acid to remove the galvanization. Muratic acid is extremely corrosive and will burn you, you must use heavy duty chemically rated gloves and DO NOT breath the fumes.
Old May 25th, 2009, 10:48 PM   #13
N8sBroncoMI
Boones Farmer
N8sBroncoMI's Avatar
sounds like a bad ass thing to be doing in the back of a truck lol
any way i dont see any thing wrong with replaceing the clips and bolts. but what about the top 3 that go into the roof theres no clip. I dont know if there the same thread. just thinking i got a 90, and a 96 never took the top off the 96
N8sBroncoMI is offline   Reply With Quote
Old May 26th, 2009, 01:18 AM   #14
Never_Evil
I'm the last of the hard asses of America, I drink the stuff for breakfast! Just kidding. I was hoping people would be smart enough to have both doors wide open and the tailgate down.
Page generated in 0.36189 seconds with 65 queries
