Dimple dies - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2009, 08:36 AM   #1
DUNE JUMP
DUNE JUMP's Avatar
Default Dimple dies
Thanks to Danza, here's a link to some inexpensive dimple dies on ebay, made in Texas.
Dimple Dies
Good for occasional use, as I don't think they're heat treated.
Old May 22nd, 2009, 10:33 AM   #2
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Dimple Dies
yep, im gonna buy a set off ebay this weekend i think.
I'm the man in White.
Old May 22nd, 2009, 10:39 AM   #3
1badzuk
1badzuk's Avatar
they also make sweet ..um "shifter nobs" http://cgi.ebay.com/ebaymotors/ws/eB...2BSI%26otn%3D4
1badzuk is offline   Reply With Quote
Old May 22nd, 2009, 10:43 AM   #4
DUNE JUMP
DUNE JUMP's Avatar
X100 8" long and 2" wide, "perfect for the harcore offroader" I think it replaces the entire shift lever, or it ought to...
Old May 22nd, 2009, 10:44 AM   #5
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I read about those on pirate the other day. Lots of good info from there.
http://www.pirate4x4.com/forum/showthread.php?t=786210
This sounds pretty good to me, I'm guessing for the home user, that should be quite a while.
"And one of my sources says 1018 is fine for several hundred holes before needing to be remachined."
JohnnyJ is online now   Reply With Quote
Old May 22nd, 2009, 11:06 AM   #6
1badzuk
1badzuk's Avatar
couldent you get these cryo treated to add a boatload of longevity out of them?
Old May 22nd, 2009, 11:08 AM   #7
1badzuk
1badzuk's Avatar
are you talking about the shifter or the dies?
Old May 22nd, 2009, 12:33 PM   #8
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
The problem is that it's still 1018 and not tool steel. You can't heat treat & cryo into something it isn't.
But, for the $140 you probably could buy a few sets and use them as-is before buying the real deal.
Old May 22nd, 2009, 03:03 PM   #9
1badzuk
1badzuk's Avatar
well if brake rotors last 3x-5x longer in wear resistance from cryo it seems that dimple dies could benifit in the same way
Old May 22nd, 2009, 03:13 PM   #10
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
looks like they sell 4140 heat treated ones for $244.00
http://cgi.ebay.com/ebaymotors/Dimpl...motiveQ5fTools
samurai2240 is offline   Reply With Quote
Old May 23rd, 2009, 01:41 AM   #11
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
you could just have them case hardened or even nitrided. Makes them a ton harder on the surface, like up to 50-55 RC on the case hardening, maybe 60 Rc on the nitride?
Mulely is offline   Reply With Quote
Old May 23rd, 2009, 06:51 AM   #12
There's a lot of misconception about cryo treatment. There's also some snake oil people out there selling it. Cryo treating only works on a heat treated material where it takes some of the retained austenite and transforms it into martensite. This process also helps the grain structure a little bit. It can only be done on a heat treatable material as Johnnyj said. You would be wasting your money to cryo 1018. I have had several conversations with our heat treater about cryoing parts as we heat treat hundreds of parts per week. To do proper cryoing, a part should be cryoed within 4 hours after coming out of the heat treat quench. Otherwise, you get very little benefit from the process. In fact, they tell us we are wasting our money to do it afterwards. I specifically asked him about sending him my axle shafts & he said I would get no benefit on a used axle shaft.
Yes, you could case harden them (carburize) but they will change shape and surface finish in the process. For what they do, that probably wouldn't be a problem but there's no guarantee on that. When there's only $100 difference between the 1018 and the 4140, your end result cost wouldn't be worth it. I thought about nitriding them but I don't know the cost of that.
IMO, the best way to use them is as is and grease the hell out of them when you use them.
BTW, where is the info that cryoing brake rotors gives 3x the life?
Old May 23rd, 2009, 08:39 AM   #13
Tab
Tab's Avatar
Check out the big brain on Jim today! Your supposed to save those five dollar words for work ya know. Do you think the 4140 would last much longer than the the 1018?
Old May 23rd, 2009, 08:46 AM   #14
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
and all that smart guy stuff before 7am on a saturday.
Old May 23rd, 2009, 08:56 AM   #15
Tab
Tab's Avatar
Ya Jim, don't use up all your brain power by 9am. Save a bit for later I just read through the pirate thread and the info is basically the same as what Jim said (as expected) and it appears with proper prep and lube the dies will last a long, long, time. I may just get the cheaper ones and check them out. Really for the price I can get the full set and add a few extras of the more common sizes if they wear out in 5 years.
Old May 23rd, 2009, 09:57 AM   #16
1badzuk
1badzuk's Avatar
A study in 1994 (6) showed that the reduction in retained
austenite was only part of the reason for the increased
wear resistance. This research confirmed the precipitation of fine
(eta) carbide particles. The deep cryogenic processing (soaking at
liquid nitrogen temperatures (-320oF)) as compared to what is
termed ‘cold’ treatment (soaking at dry ice temperatures (-120oF))
both reduced the amount of retained austenite. But the deep
cryogenic processing increased the wear resistance of the materials
tically, especially at high sliding speeds’. Figure 3 shows the
comparison of wear resistance vs. sliding speeds on both treated and
untreated samples.
http://www.cryoplus.com/pdf/icwptct.pdf
lots of good info showing cryotreating improved wear reisitance
Old May 23rd, 2009, 10:03 AM   #17
1badzuk
1badzuk's Avatar
Bill heard a term, "Cryogenic Tempering," at a fleet maintenance trade show, and he wondered what it had to do with ambulances. He soon discovered that treating brake rotors using computer-controlled cryogenic temperatures at minus 300 degrees (F), increased the life of the rotors and the pads by 250-400%. The technology was unconditionally guaranteed or his money back...
http://www.300below.com/site/efrp.html
just one of many sites telling how cryo helped with wear resistance for brakes
Old May 23rd, 2009, 10:19 AM   #18
TurboChris
TurboChris's Avatar
Also you cant heat treat a finished product, it has to be a unfinished product then machined.
TurboChris is offline   Reply With Quote
Old May 23rd, 2009, 12:03 PM   #19
95geo
newbie
95geo's Avatar
yes you can, jmr dies are machined within .010" then heat treated and then finish machined. the light racing dies are completely machined and then heat treated and the end user has a part straight from heat treat, no post machining.
all I can say is it's about damn time someone came out with dimple dies for what they should be worth, not what they're worth to you over a 10 year period of use.
I'd spring for the chromoly ones, if you are pushing two pieces of the same material together they both are going to gouge equally and with one having a sharp corner I bet you will see some decient wear on the first fet parts. it's only a few bucks more and the chromoly will last a lot longer and not rust up as easily. keep them lubed up even when storing and they'll look new for years.
Old June 1st, 2009, 08:33 AM   #20
DUNE JUMP
DUNE JUMP's Avatar
Got a 1 3/4" in the mail over the weekend-- 1018, looks pretty good. Tried it out last night and I'm happy with it, dimple has good shape and a tight edge--
Page generated in 0.40339 seconds with 83 queries
