99 trans into a 94???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 22nd, 2009, 07:28 AM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default 99 trans into a 94????
94 1500 2wd 318 i lost reverse on my way home from r&v last weekend. can i use one from a 99? or can i swap the motor and trans?
i found this (down)
99 Dodge ram engine and trans - $500 (Livonia, MI)
Reply to: sale-39f9n-1141114196@craigslist.org [Errors when replying to ads?]
Date: 2009-04-26, 8:43PM EDT
Engine and trans from a 1999 dodge ram 1500 2 wheel drive. Engine (5.2) had 105,000 and trans had 40,000 (rebuilt by factory). Both were running perfect, but i totaled the truck (no damage to engine/trans). Asking $500 for engine, $400 for trans, $800 for both, or best offer. They are still together as one unit, and with all of the wiring as well. Had planned on swapping it into another vehicle, so it was taken out with care...not just cutting/hacking all the wiring.
Mike
it's NOT ok to contact this poster with services or other commercial interests
luvitmyjeep is offline   Reply With Quote
Old May 22nd, 2009, 07:43 AM   #2
Tom
Because racecar
Tom's Avatar
no, the 94 is a 46rh, and the 99 is 46re. The 46re is electronic and the 46rh is not.
Old May 22nd, 2009, 07:45 AM   #3
luvitmyjeep
broken
would it work if i do the whole swap? motor and trans?
Old May 22nd, 2009, 08:01 AM   #4
Tom
Because racecar
Tom's Avatar
You'll need the complete wire harness, computer, ect. it's a lot more work then just finding the correct trans or having your current one rebuilt.
Old May 22nd, 2009, 08:03 AM   #5
luvitmyjeep
broken
thanks!! you just saved me $600
Old August 22nd, 2009, 01:37 AM   #6
Tony5402
FWIW. Loss of reverse in a 46re doesn't necessarily mean the trany's toast. Common failures would be broken or cracked servo, torn servo seal, or a broken reverse band strut. All of which can be repaired without pulling the unit as long as you don't smoke the band.
Tony5402 is offline   Reply With Quote
Page generated in 0.15900 seconds with 41 queries
