Thread Tools
Old June 11th, 2006, 10:17 PM   #1
SS
Fight! Fight! Fight!
SS's Avatar
350 Pistons
Chevy 350 piston question for you guys
It's a 1977 Chevy 350 with a stock bottom end, milled heads, 3 angle valve job, crane cam, edelbrock performer rpm intake and headers. The block is cracked along a water jacket so I'm having the block swapped out and while it's apart I figured I might as well get the compression up a little bit since it is a 77 motor and is probably pushing 8.5:1 or close to it.
I'm not looking to pushing it to the max here... just a little more power out of it.
Should I go with domed, dished or flat top pistons and what's the difference? I'm trying to shoot towards a 9.5:1 CR but I'm not also out to break the bank here.
Looking to spend a max of around $200 for the set with rings.
Iron or moly rings?
Any brands to stay away from?
-Jeremy
SS is online now   Reply With Quote
Old June 13th, 2006, 02:20 PM   #2
CHVYPWR
D.I.L.L.I.G.A.F.
CHVYPWR's Avatar
Flat tops would be the way to go with what you have.
Old July 11th, 2006, 11:40 AM   #3
halfgassed
halfgassed's Avatar
if your lookin gfor a good value in jegs I believe they were silvolite has some hypereutic (SP?) pistons that when used with a 64cc head had a compression ratio of 10.3:1, and cost about $120 for all 8. I ran them in a motor I built 25,000 miles ago and still holding strong after lots of abuse. Good value, if your heads are 76 cc chamebr it'll probably lower the comp ratio closer to what you desire.
halfgassed is offline   Reply With Quote
Old July 11th, 2006, 11:57 AM   #4
How much was milled off the heads? Have you checked the CC volume on them after milling?
Haggar is online now   Reply With Quote
Old July 11th, 2006, 02:38 PM   #5
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
I put dome top with 305 heads on my 350 and it pushing 12:1 or alittle higher of course along with other poopoo
Dirty Minds Jeep Club
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
[SIGPIC][/SIGPIC]
Deaner is online now   Reply With Quote
Old July 11th, 2006, 05:46 PM   #6
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the stock pistons are junk anyways. the tops are releived to give about 7.8:1 stock. they are piss poor for the year your working with. the crank should be ok but everything else that came stock in that motor sucked
If I was building it I would use TRW flat tops with single valve reliefs
Originally Posted by Gradowski View Post
" Treat 'em like a dog and they'll love you like a puppy!"
Old July 11th, 2006, 06:28 PM   #7
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
wasn't all this covered in another thread you sarted... Flat tops, molly rings have a nice day
Old July 11th, 2006, 11:21 PM   #8
SS
SS's Avatar
Yes. That's why I'm suprised this thread is alive
-Jeremy
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.14618 seconds with 26 queries
