Jeep Parts for Sale, 3/4 Ton Jeep Axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2006, 08:55 PM   #1
nosler45
Confused
Exclamation Jeep Parts for Sale, 3/4 Ton Jeep Axles
Parts from a 1974 Jeep J20
- Steering column(Non Tilt), Steering wheel $30
- Power steering pump $30
- Power Steering Box w/mount, shaft $50
- Hood, Hood hinges(Still held the hood up just fine) $10
- Windshield and rear glass $20 each
- 2bl intake and carb. The carb ran good $30
Also have the axles for sale on Ebay: Front Dana 44 and Rear Dana 60 Full Floating. Check it out at! Item # 8072370482
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
nosler45 is offline   Reply With Quote
Old June 11th, 2006, 09:39 PM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
not sure when I'd be able to get to Ft. Wayne (I assume thats where the stuff is) but I'm interested in buying the windshield and rear glass.
Old June 11th, 2006, 10:42 PM   #3
nosler45
Confused
When you do, just let me know, and if I have to head up north I will PM you. Have not had any interest in it locally, so it is just stored out of the way. If you want pics, I can send them to you if you provide me with an email. The glass is located in Ft Wayne. I could also hold for you for awhile?
Thanks,
Nosler45
Old June 12th, 2006, 05:48 AM   #4
78cj7
build it break it learn
78cj7's Avatar
Default power steering box
any info or pics on the power steering box, is it the same for a 74 as a 78 if so I will take it if it doesn't leak and has no excessive play. any info or pics to knappenburger@hughes.net
78cj7 is offline   Reply With Quote
Old June 12th, 2006, 02:58 PM   #5
PavementPounder
PavementPounder's Avatar
I'm going to Hudson, Indiana in a few weeks.
Old June 12th, 2006, 11:41 PM   #6
nosler45
Confused
It is off a J20 Jeep Truck, ,not sure if it is the same as the CJ. I will check it out tomorrow, just got off work. Then I will send pics. I have a 79 CJ w/ pwr steering, so I will compare and get back to you.
Thanks,
Nosler45
Old June 12th, 2006, 11:44 PM   #7
PavementPounder
It may look the same externally, but what he is asking is whether it is a big-bore model like on the later J-20's.
Old June 13th, 2006, 12:03 AM   #8
nosler45
Confused
If your interested Brewmenn I can send pics and then maybe even meet PavementPounder in Hudson?
Thanks,
Nosler45
Old June 13th, 2006, 12:05 AM   #9
nosler45
Confused
How would I determine if it is the Big Bore model?
Old June 13th, 2006, 05:42 AM   #10
78cj7
78cj7's Avatar
Default part numbers match
I just looked it up at autozone and they list the same part number for both years so it should be the same I would guess as long as it was power steering and wasn't swapped previously. As far as looking at it externally and telling the difference PP might have a better idea if there is a way to do that, but comopare it to your cj7 box it should look the same maybe just a bigger shaft would be all.
Old June 13th, 2006, 06:08 AM   #11
PavementPounder
Yeah, I'd call the parts stores and compare the part #'s. Call more than one, though - and make one of them a NAPA.
Old June 14th, 2006, 11:33 PM   #12
brewmenn
brewmenn's Avatar
Thanks,
Nosler45
That'd work. send pics (but I assume it looks like a windshield and a window):miff: and I assume thier unbroken. brewmenn@yahoo.com
PavementPounder, let me know when your going.
Page generated in 0.40976 seconds with 59 queries
