2 Ford Dana 60 front ends (Sold /// Please remove ) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2009, 10:17 AM   #1
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Default 2 Ford Dana 60 front ends (Sold /// Please remove )
Like the title says I have a ford dana 60 front. It has kingpin knuckles locking hubs and 4.10 gears. I bought this not too long ago but I'm not gonna use it. Its gonna probably need brakes and bearings repacked. As far as I know there is nothing wrong with it. There are calipers included, but I don't know if they are good, you could use them for the core though. This axle came from a 88 or 89 f350 srw. I also have a set of 3.55 gears that I could throw in for no charge. And I have a rear end to go with it with 3.55 gears. $1100 takes it all. Its not availble for about another 2 or 3 weeks though. I'm overseas right now and won't be homw until then. The axle is in midland, Mi. I could deliver it for cost of my fuel.
EDIT: For an extra $200 I'll throw in another dana 60 front. It has ball joint knuckes from a 92 f350 srw. hubs, rotors, brakes and axle shafts are there. The carrier and gears are the ones I said I would include with the other axle above. The only wrong with this axle is the housing has crack in it. So basicly for $1300 you get 2 dana 60 fronts and a rear end, all complete hub to hub.
BAD93SBLZR is offline
Old May 22nd, 2009, 05:46 AM   #2
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
bump
Old May 24th, 2009, 04:20 AM   #3
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Bump for the weekend
Old May 25th, 2009, 08:35 AM   #4
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
bump//// May consider trades
Old May 25th, 2009, 08:59 AM   #5
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Had 2 offers on the cracked one. (PMs sent) Anyone interested in the good one. PM me with any questions.
Old May 26th, 2009, 12:00 PM   #6
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Somebody must want these//// Bump
Old May 27th, 2009, 12:43 PM   #7
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
ttt
Old May 27th, 2009, 07:55 PM   #8
camccardell
tiger blood
camccardell's Avatar
it's not like we don't want em, we just don't have that much cash!
camccardell is offline
Old May 30th, 2009, 01:19 PM   #9
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
ttt
Old June 14th, 2009, 02:44 AM   #10
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
bump
Old June 14th, 2009, 08:00 AM   #11
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
interested in the knuckles out from the cracked one
Jeepaholic is offline
Old June 14th, 2009, 08:50 AM   #12
mudbillyredneck
mudbillyredneck's Avatar
Pics of crack ...I'll buy the whole axle with gears for the $200
mudbillyredneck is offline
Old June 14th, 2009, 10:45 PM   #13
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Here are some pics of the cracked one.
Old June 15th, 2009, 07:49 AM   #14
mudbillyredneck
Oh....thats alittle worse than I had hoped ? But its just ganna get welded and run through the mud so it should still work fine for what I need
Send me contact info in a pm with availability for pic up ?
Old June 16th, 2009, 07:22 PM   #15
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
pm sent
Old June 16th, 2009, 07:29 PM   #16
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
88 ford dana 60 front /// 4.10 gears /// $900 any takers?
Old July 14th, 2009, 12:10 PM   #17
Bad Influence
Interested in a set of (4) 16.5 X 12, 8 LUG, 6.5 center hole, 6 inch back spacing,
Eagle Alloy Aluminum wheels, with center caps and some $$ for the 88 Dana 60?
Wheels are like new, no scratches, never seen salt.
Lets deal.....
Bad Influence is offline
Old July 30th, 2009, 04:39 PM   #18
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
SOLD The the good dana 60. Still have the one with a crack in it
Old July 31st, 2009, 09:40 AM   #19
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Deal pending
Old August 2nd, 2009, 09:45 PM   #20
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
both gone now
Page generated in 0.39793 seconds with 83 queries
