Scar face my 95 xj 2 door build - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2009, 12:14 AM   #61
cj7on44's
cj7on44's's Avatar
got my arms home at 9 and just came in from putting them on. :) still need to tighten all the bolts.
cj7on44's is offline   Reply With Quote
Old December 8th, 2009, 12:25 AM   #62
MiNi Beast
MiNi Beast's Avatar
Hey good deal man. Go big or go home right?
Want pics want pics
And hey thanks I got that flange last friday to.
Old December 8th, 2009, 12:28 AM   #63
cj7on44's
cj7on44's's Avatar
haha i will have some pics tomorrow.
Old December 9th, 2009, 11:04 AM   #64
cj7on44's
cj7on44's's Avatar
here are a few pics not the best i will get some better ones once i get it all cleaned back up and in the light
ID:	54004   Click image for larger version
ID:	54005   Click image for larger version
ID:	54006   Click image for larger version
Old December 9th, 2009, 08:41 PM   #65
drew91xj
drew91xj's Avatar
what was the reasoning of welding the link mount to the unibody just strenght or? just curious havnt seen that done with a clayton before
Old December 9th, 2009, 10:25 PM   #66
Soy_bomb
Web Wheeling!
Soy_bomb's Avatar
I believe Clayton Offroad recomends welding it. I could be wrong though.
Soy_bomb is offline   Reply With Quote
Old December 9th, 2009, 10:29 PM   #67
MiNi Beast
MiNi Beast's Avatar
yep
Clayton Off Roads package deal lift kits are specifically designed to offer the best all around performance. This kit is put together using only the highest quality parts, and vigorously tested to meet our stringent requirements. Because this is a package deal lift kit, you know that everything is going to properly work together, to give you the best performance possible. Making bulletproof arms is our name to fame and we back that with our lifetime warrantee. But thatís only one step of the equation. When this package deal was put together we had one main goal in mind. We wanted to build the strongest, most reliable long arm kit on the market. Price is important, but quality has to be a priority. Ease of installation is also very important, but strength and reliability has to be above the rest. If you save a few hundred dollars, and it falls apart in 6 months, thatís not saving money. If you can install it for less or faster, but it fails or leave you stranded in the woods, thatís not saving time or money either. These are all items we thought about when designing, installing and testing our lift kits. Our obsession to details, is what brings you the best riding, strongest most reliable lift kits on the market, period.
This specific 4.5 inch Cherokee XJ lift kit was designed to run 31 inches tires. Kit includes, a front 3 piece cross member, upper and lower front adjustable control arms with hardware, front spring retainers, front and rear brakelines, front coil springs, front adjustable trackbar, front sway bar disconnects, rear heavy duty leaf springs with u-bolts and degree shims. Shocks are optional and we recommend the Bilstein 5100s.
Key Features
# Weld on design for Maximum Strength
# Fully Adjustable Control Arms
# Premium Adjustable Trackbar
# Quality Military wrap leaf springs with pressed in bushings
# DOT Approved Stainless Steel Brakelines
# Easy upgrade to our 6.5 or 8 inch kits
# Lifetime Warranty
Old December 10th, 2009, 12:21 AM   #68
cj7on44's
cj7on44's's Avatar
yeah like mini beast posted welding is recommended by clayton
Old December 10th, 2009, 08:25 PM   #69
drew91xj
drew91xj's Avatar
well i figured there was a reason just never read the full description mini beast posted just curious.
Old December 10th, 2009, 09:12 PM   #70
MiNi Beast
MiNi Beast's Avatar
Key Features
# Lifetime Warranty
Lazy SOB
Old December 10th, 2009, 09:13 PM   #71
drew91xj
drew91xj's Avatar
hey hey i said i must not have read it my bad
shouldnt u be working on yours sorry bout the hi jack
Old December 10th, 2009, 10:53 PM   #72
cj7on44's
cj7on44's's Avatar
the ride is way better with the longarms than it was with the short arms
Old December 10th, 2009, 11:18 PM   #73
MiNi Beast
MiNi Beast's Avatar
duh.
Old December 11th, 2009, 11:47 AM   #74
cj7on44's
cj7on44's's Avatar
Originally Posted by MiNi Beast View Post
duh.
haha yeah i know but i didn't think i would be as big of a diff.
Old December 11th, 2009, 05:29 PM   #75
drew91xj
drew91xj's Avatar
mini is just jealous he doesn't have one going...
Old January 12th, 2010, 01:41 AM   #76
cj7on44's
cj7on44's's Avatar
haven't updated in a while but blew my rear end apart so got a parts xj for 200 with a hp d30 and a 8.25 with 3.55 got the rear in shortened up my shock mounts so they dont hang as low and boxed them in and im waiting on the front till i go pick up a newer axle housing from my buddy cause my current one is bent and the other one is really rusty and crappy looking. i'm fabbing up some disks for the rear using xj front calipers and rotors. and will soon be swapping the front sheet metal over to the 97+ already have the newer style mirrors.
Old January 13th, 2010, 02:43 AM   #77
cj7on44's
cj7on44's's Avatar
face lift started tonight and rear disk brackets made :)
Old January 13th, 2010, 10:36 AM   #78
Ford forever
Bought another jeep
Key Features
Lazy SOB
From everything i have heard about welding to the uni body,
i would never weld directly to it as it could rip off the uni body
cause its so thin or easily tear the uni body. But i have only seen
one arm ripped off the unibody so maybe it was just a fluke.
Ford forever is offline   Reply With Quote
Old January 13th, 2010, 11:12 AM   #79
Asher
Jack stand wheeler
Asher's Avatar
This isn't Clayton Offroads first rodeo. If they say to weld it on its a safe bet that's the best way of doing it.
Asher is offline   Reply With Quote
Old January 13th, 2010, 05:08 PM   #80
cj7on44's
cj7on44's's Avatar
got the front all done ds fender and hood needs primer till spring then repainting the whole thing.
Page generated in 0.43672 seconds with 84 queries
