Home made wood half doors - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 18th, 2009, 09:52 PM   #1
alumitub78
alumitub78's Avatar
Default Home made wood half doors
So I decided to make some half doors for four wheeling. I think they turned out pretty nice, and only cost me about $50.00 to make. So if I ruin them offroad it will be a lot cheaper to replace than my full steel doors. Here is how I did it:
First I traced the bottom of my steel door onto some poster board and then transfered that to some 1/4" plywood. After cutting them out I made some templates for hinges with cardboard and transfered that to 1/8" steel. Cut and bent the hinges and welded bolts in them.
I then glued some 1/8" hardwood pressboard on the outside of the doors. This gave me a smooth surface to paint and added a lot of strength.
After that I added a wood brace and stappled some garage door foam to the inside. Also I used a chain bolt for a house door as a latch. It works perfect on my jeep.
Finally I sprayed them with wood primer and some duplicolor spray on bedliner. Here is the finished product:
alumitub78 is offline   Reply With Quote
Old May 18th, 2009, 10:01 PM   #2
TS-Off-Road
989-832-4999
TS-Off-Road's Avatar
OK, you have a $4000 aluminum tub and you are worried about your doors???
JK!
Looks good!
Heck, you could even skin them over with some 14g Al to match the tub.
TS-Off-Road is offline   Reply With Quote
Old May 18th, 2009, 10:02 PM   #3
xj97sport
atv rider
xj97sport's Avatar
fuck i suppose ... it is cheap
Old May 18th, 2009, 10:14 PM   #4
capone
capone's Avatar
Good Job
capone is offline   Reply With Quote
Old May 18th, 2009, 10:59 PM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
JK!
Looks good!
heck yes skin them with AL to match the tub
http://www.apalansing.com/
Old May 19th, 2009, 07:44 AM   #6
alumitub78
alumitub78's Avatar
Well back when I bought the tub it was $2,600 which at the time was only $600.00 more than a steel replacment tub. Definitly couldn't afford one now. I think I will leave them black, keeps them cheap and breaks up the aluminum a little.
Old May 19th, 2009, 09:11 PM   #7
OldSlowReliable
extra on the SLOW
OldSlowReliable's Avatar
Wow, those look GREAT
I woulda never thought of that......mind if i try it on my pathy later this year possibly? :-)
OldSlowReliable is offline   Reply With Quote
Old May 19th, 2009, 09:30 PM   #8
alumitub78
alumitub78's Avatar
Thanks, and actually this wasn't completely my idea. My friend sent me an old post in the TJ section on jeepforum and thats where i got the idea. I changed it around a little to try to make them look a little nicer. I posted it up here so people would now how to do it if they wanted to anyways.
Old May 20th, 2009, 08:32 AM   #9
dreezy
Haggard Fab
dreezy's Avatar
I think you should have stained them.
Page generated in 0.25653 seconds with 50 queries
