Help, rings or valve seals? 22re - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 17th, 2009, 06:56 PM   #1
wickedlowss
wickedlowss's Avatar
Default Help, rings or valve seals? 22re
what do u think ? 20,000 miles on 22re motor rebuild when i bought the truck, cylinders look really good, burning oil on startup and when under load. Valve seals or rings...Any ideas
wickedlowss is offline   Reply With Quote
Old May 18th, 2009, 06:31 AM   #2
wickedlowss
Default bump
bump
Old May 18th, 2009, 08:31 AM   #3
Did you do a compression and leakdown test on it before pulling the head?
Old May 18th, 2009, 04:24 PM   #4
wickedlowss
Default yes and no
I did a compression check, got some good numbers, but i didnt know about a leakdown test until after i had the head off
Old May 19th, 2009, 06:14 PM   #5
wickedlowss
The other 3 cylinders look perfect this is #1 it has some vertical marks, does this look like a broken ring ?
Old May 19th, 2009, 06:17 PM   #6
wickedlowss
Default #1 cylinder
Old May 19th, 2009, 06:19 PM   #7
Bishop
Bishop's Avatar
it would have been sooo much easier to give a good answer before it was disassembled.
now by looking at pictures its a 50/50 guess
Old May 19th, 2009, 06:32 PM   #8
xjmichigan
xjmichigan's Avatar
A complete rebuild, or just lower end/top end?
Old May 19th, 2009, 06:46 PM   #9
wickedlowss
I bought from a guy who owned it for 2 months and sold it because he was moving out of state..also a complete moron. the guy he bought it from "Rebuilt" it, The block has definitely been out, its painted in places that i don't think u could get without pulling the motor. Not sure on the head it looks very clean if it did have 220,000 miles on it, its kinda unknown history to me .
Old May 21st, 2009, 03:51 PM   #10
wickedlowss
Default burning oil
I pulled to off a few of the valve springs and two of the valve guides were busted off so .. i guess that is where my oil is coming from..
Also has been rebuilt at some point it has .50 over pistons in it
Page generated in 0.41219 seconds with 53 queries
