360 TBI to Carb - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 14th, 2009, 02:54 PM   #1
Spec Ed
I Break Stuff!
Spec Ed's Avatar
Send a message via AIM to Spec Ed
Default 360 TBI to Carb
After having serious wiring issues on my 91 W250 with a TBI 360, I have decided to change it over to carbureted.
Has anyone on here done this?
Can I use the existing intake manifold? If so, what style of carb does it need?
Do I have to change the distributor?
Do I have to change the fuel pump?
Thanks in advance for any help.
Spec Ed is offline   Reply With Quote
Old May 14th, 2009, 03:03 PM   #2
greygoose
I'm the dude
greygoose's Avatar
I would assume you have to change the fuel pump. If I remember correctly, EFI needs a lot more pressure than a carb setup. I would think the distributor would be fine. A guess would be you need a new intake.
Old May 14th, 2009, 03:12 PM   #3
Freak
Wheelin the HD
Freak's Avatar
TBI to carb I don't think you would need a new intake unless the bolt holes wont line up.
Page generated in 0.24464 seconds with 32 queries
