89 jeep yj - ford 302,aod, np205 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 13th, 2009, 05:52 PM   #1
alltwistedup
alltwistedup's Avatar
Default 89 jeep yj - ford 302,aod, np205
new price $6,000 at the end of the month i part it out
more pics at http://rides.webshots.com/album/571835784ZAyXrY ask and i will sent you more as i have over 400 build pics.
$8,000.00 cash, firm, I will deliver to your location (with in 150 miles) via trailer, jeep will be on castor wheels for mobility ( see not included in sale )
I am only selling as I was going to changing the drive train and it wont all fit so i purchased another vehicle as a platform. I can not even begin to tell you all the hours and $$$ that I have invested in the jeep. Save yourself time and money just put your own axles and suspension under a proven drive train. currently it sits on 37" tires for reference, jeep turns heads anywhere it goes sounds and looks good.
Body/ Frame/ Title 1989 jeep yj
Heater fan motor for a 1973 gm blazer
Headlight buckets cut for custom radiator installation
Custom built dual battery tray for yellow top Optima’s
Custom built cross member so front drive shaft can pass threw
Custom built fan shroud
Custom rock sliders with foldaway steps
Custom rear bumper with 37” tire carrier and hi-jack carrier welded in to the frame
Hood pins
Winter full hard top gray and red doors, Summer Rock It gear fullback and 2 piece doors grey
Rear LED tail and side lights, front upper side marker located in the hood
Earl’s and aeroquip adapters to connect ford power steering line to jeep 89 yj power steering box
Stock pitman arm drilled out taper
7” jeep tj fender flairs cut to look like a flat fender jeep
Frame is set up for rear tj coil spring the front leaf spring hanger were removed and refabbed
Engine 1984? Ford f-150 302 cid 10,000 miles on rebuild by Michigan motor exchange ( it runs great )
Reman long block motor
Edelbrock performer intake
Edelbrock performer 650 carb electric choke, off-road kit
Edelbrock valve covers
Edelbrock air cleaner
new starter
Fuel filter Fram g1
Dual oil filters Fram ph43
Be-cool radiator for stock yj custom mounting 13 lbs cap
18” flex fan
1.5” x 18” flexible upper radiator hose
1.75” x 14” flexible lower radiator hose
MSD A6 and Blaster coil ignition
MSD billet distributor
Bosh 8mm plug wires
Lokar tv cable for aod
Lokar throttle cable 36”
Headman headers, exhaust system 2 1/2” w/ 2 into 1 muffler
Transmission 1980’s ford aod 10,000 miles on rebuild
B & m shift kit
B & m quicksilver shifter
B & m shift arm upside down for drive shaft clearance
Lokar fire wall mount dipstick for aod
Perma-cool 18-25,000 gvw trans cooler on custom brackets
Transfer case 1979 ford f-250 np-205
1.96 stock low range
Twin sticked
Front yoke in the rear
Drive shafts are both front shafts for the cv joint
Also included in the sale
Ford c6 transmission long shaft includes torque converter with approximately 1,000 miles on rebuild
Edelbrock re-jet kit
Ford aod transmission pan (I was going to make it a deep pan)
both hard and soft top set ups
***************************** Not included in the sale *****************************
braking system including cutting brake, master cylinder, proportioning valve, line lock and all brake lines
front axle assembly, track bar, Tie rod and drag link, front springs, sway bar assembly
rear axle, rear springs (available separate), rear control arms, rear shocks, both front seats, battery, tires and wheels
alltwistedup is offline   Reply With Quote
Old May 13th, 2009, 06:04 PM   #2
Hooperdog
OllllO
Hooperdog's Avatar
What axles?/ gears?
Hooperdog is offline   Reply With Quote
Old May 13th, 2009, 06:37 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Read the last part *Not* included
Old May 14th, 2009, 11:31 AM   #4
alltwistedup
it has a d44/d60 with 4.10s locked, but they are going in the new project s10 that is why they are not included. its not cheap to put high steer on and rebuild every piece and add disk brakes to the rear. if you want them bad enough i can add the $$$$ up.
Old May 16th, 2009, 08:47 AM   #5
alltwistedup
bump
Old May 18th, 2009, 06:11 PM   #6
alltwistedup
ttt
Old May 22nd, 2009, 11:18 AM   #7
alltwistedup
if your going to look at least give me some feed back
Old May 22nd, 2009, 07:11 PM   #8
cgrooters
Oh Snap
cgrooters's Avatar
Well first, i do believe that 8,000 for a jeep with out braking system including cutting brake, master cylinder, proportioning valve, line lock and all brake lines
rear axle, rear springs (available separate), rear control arms, rear shocks, both front seats, battery, tires and wheels is a little bit crazy. A person is going to have to put another couple thousand into this thing just to get it wheel-able...... Perhaps lower the price about 5k and it might sell.... But that's just my $.02.
You said to leave feedback if we are checking it out....So i did... Not meant to sound like an ass either...
cgrooters is offline   Reply With Quote
Old May 22nd, 2009, 10:49 PM   #9
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
You will sit on this vehicle for a while.
Old May 23rd, 2009, 08:50 AM   #10
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
Absolutely.
I'd part it out if you're going to strip that much off it.
SlayerXJ is offline   Reply With Quote
Old May 23rd, 2009, 11:31 AM   #11
alltwistedup
thank you for the feedback it nice to know what other people are thinking.
cgrooters, i have about 4g wrapped up in the motor alone i am already losing $$$ but i gained experience building it so its not that bad but i cant give it away.
rob the plumber, slayerxj i know this has got to be the worst time to sell a ride, i have been out of work for 6 months. everyone in this state is selling everything and buying nothing.
i am hoping not to part it out as its a great looking and running set up that some one could just put different axles under (44/9, 44/60, 60/14, 2 1/2's, mog axles). i would take less off of it but i need those parts for the s10 build it took a while to match it all up, i still will be replacing some stuff.
would it be more appealing if i put some stock axles under it or just part it out?
Old May 23rd, 2009, 01:35 PM   #12
96 s10 blazer
96 s10 blazer's Avatar
even parting it you wont ever come close to the asking price he wants for this.
MI = no resale value
96 s10 blazer is offline   Reply With Quote
Old May 25th, 2009, 03:38 PM   #13
Rob the plumber
A stock longblock 302 with a carb and intake should be nowhere near 4 grand. You could have an aluminum headed Windsor for that.
Old May 31st, 2009, 09:38 PM   #14
alltwistedup
you are total correct its all the other stuff that adds up
ramchargers carb jets, offroad kit $48.70
damman oil line fittings $6.96
michigan motor ex longblock 302 $2,019.30
ramchargers elbrock carb, intake, misc $476.96
murrys elbrock valve covers $54.00
mazza fuel line fitting $4.82
ramchargers msd distributor $218.53
murrys water hose,water outlet, thermostate, brake/fuel line $46.78
autozone plug wires $52.00
autozone starter sol $16.71
mazza starter $49.15
autozone altenator, belt $110.89
reliable auto muffler dual 2.5/2.5 $148.35
autozone f150 lower rad hose $7.83
forrest's exaust pipeing $120.00
ramchargers msd ing. & coil $203.50
murrys heater hose $10.15
$3,594.63
these are 2004 prices and does not include everything
Old June 1st, 2009, 01:48 PM   #15
Rob the plumber
I understand all that, but lets say you have an average 1994 Z28 Camaro that is worth $4000. You have a shop replace the motor at a cost of $3500. This does not make the car worth $7500.
I understand your position, but it can be very difficult to get back money from "mods". The biggest red flag for your sale is how you don't get all this stuff for $8000.
$8000 is what people really expect to pay for a clean, V8, ready to rock YJ. Maybe you will get lucky though.
Old June 1st, 2009, 11:01 PM   #16
NuckinFoob
i agree with everyone else. You don't get nearly what you put into a vehicle, out of it. Luckily, wrangler prices are awesome for sellers right now, and 8,000 would be a fine deal for your vehicle as-is.
However, spending 8k on it and needed to put thousands more into it is unappealing. Shit 10 grand is a decently modded TJ.
This will never sell for 8,000 with all the pieces missing, this is essentially a project jeep. Thats going to need a lot of parts an a lot of labor to get it moving.
I have sold lots of modified vehicles and one thing you learn quick is that your 4,000$ vehicle with 10k invested is not worth anywhere near 14k. You'd be lucky to see 8k.
NuckinFoob is offline   Reply With Quote
Old June 2nd, 2009, 06:29 AM   #17
comanche38
comanche38's Avatar
I agree with everyone else, too high of a price for what is actually for sale, if it were as it is with axles and brakes, it would be a good deal. There is a false thinking that when people put money into a Jeep or 4x4 that it increases the "worth" or value, in acuality it may be making it worth less because you are building it the way you want, which might not be what everyone wants. An example - I would rather have a stock motor and more upgraded axles/suspension than have $4,000 into a motor. So, to find someone that wants exactly what you are offering for this price sounds next to impossible. On a seperate note, if I had been out of work for 6 months, I would be selling the entire thing, not starting a new project, or at least keep your $4,000 motor for the next project. Of course I do not know your situation, but that is me. Good luck.
comanche38 is offline   Reply With Quote
Old June 4th, 2009, 09:55 PM   #18
alltwistedup
next project is a s10 extend cab 3rd door
Cummins 4bt, nv5600, 203/205, d44/d60 locked with 37s
notice the parts from the jeep i still need, i have the rest already i just need the room to get started.
just put #1 piston into the oil pan on the stock 2.2 today
Old June 16th, 2009, 09:37 AM   #19
alltwistedup
new price
$6,000.00
i will start to part it out at the end of the month if its still in my driveway
Old June 18th, 2009, 11:04 AM   #20
alltwistedup
bump
Page generated in 0.44027 seconds with 83 queries
