89 ranger dying out - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 12th, 2009, 10:41 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default 89 ranger dying out
having a problem with my 89 ranger 2.9 5 speed. cold start it won't run for shit when you try and push the gas, it just dies. floored it has no balls it just won't rev past like 3000. once it runs for 5 mins it runs great. does have a slight dead spot off idle. what can it be? no codes thrown either
Old May 13th, 2009, 02:09 PM   #2
92comanche4x4
92comanche4x4's Avatar
im havin kinda the same problem other than mine ill run for 30 seconds and die and have a ton of air in the lines other than mines a 88
92comanche4x4 is offline   Reply With Quote
Old May 13th, 2009, 09:23 PM   #3
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
vacuum leak?
Old May 13th, 2009, 09:51 PM   #4
firehawk
Live Action!
firehawk's Avatar
Start with checking fuel pressure.
Old May 13th, 2009, 09:56 PM   #5
Jt91bronco
Jt91bronco's Avatar
i have an 89 bronco II that acted very similar. i cleaned the top end of the motor, ran some injector cleaner, replaced the fuel pressure regualtor and replaced the oxygen sensor. it runs great now. the o2 sensor made the biggest diference
Jt91bronco is offline   Reply With Quote
Old May 13th, 2009, 10:18 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
can't find any vacuum leaks. oxygen sensor doesn't control the engine until it reaches operating temp so that can't be it. and whats the fuel pressure spec? i kinda doubt thats the problem as it only runs shitty when you first start it after it's been sitting for overnight. after not even 5 mins the problem goes away completely.
Old May 21st, 2009, 11:27 AM   #7
llxRanger
llxRanger's Avatar
Its telling you to 4.0 that silly slut.
llxRanger is offline   Reply With Quote
Old May 21st, 2009, 09:57 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
checked fuel pressure. 35-45 is the range it runs right at 35 idle 40 with vacuum line off. so thats ok. also noticed that now it will die out if you put any load on the engine. i started it up this morning and turned the wheel and it shut off. restarted no problem. i let the clutch up ever so slightly and it died again. once it heats up i can let the clutch up and get it rolling without putting my foot on the gas.
Page generated in 0.23540 seconds with 47 queries
